How do i remove lock barrel from door handle
Old Nov 14, 2015 | 05:15 AM
iownme's Avatar
Default How do i remove lock barrel from door handle
Morning all.
Driver side door handle broke so a replacement has been ordered.
I went to remove the handle but the lock barrel is preventing the door handle from coming out.
What is holding that barrel in there?
I've tried looking at pics of the setup but see nothing locking that barrel in there... Any idea how to proceed???
Old Nov 14, 2015 | 08:52 PM
Dr dome's Avatar
The black plastic funnel cap. Pry it off and the handle should come out of the door. Once out I belive the lock has a spring clip on it.
Old Nov 26, 2015 | 01:42 PM
iownme's Avatar
The funnel cap has 2 small pieces of plastic in the center. Are these to release it?, do i need to push them together or pull them apart as i pry the cap?
Old Nov 27, 2015 | 11:54 AM
iownme's Avatar
I finally did it. For anyone else searching for this answer, i put a flat blade screwdriver between the 2 tabs and twisted, forcing the tabs apart. While holding in this position a inserted a 1/2" chisel behind the cap and gently levered the cap off.
Doorhandle and lock barrel now removed.
To remove the barrel from the handle, grip the back of the barrel with vice grips and gently twist about 1/5 turn and the barrel comes out
Old May 29, 2016 | 03:01 PM
mtkraabel's Avatar
Having the same trouble. Workshop manual does not mention this piece. Just pry it off?<br/>
Old May 30, 2016 | 06:03 PM
iownme's Avatar
Yes, pry it off
CBY335
Mar 9, 2021 09:57 AM
sundude
Feb 22, 2021 08:16 PM
355rockit
Nov 8, 2015 03:15 PM
Howie
Nov 7, 2015 06:27 PM
EZDriver
Oct 22, 2015 10:10 PM
