I built my "cold" air intake finally...at least look haha
Old Mar 30, 2015 | 08:35 PM
Justink201's Avatar
Default I built my "cold" air intake finally...at least look haha
I know, another cold air intake thread... but I figured you might like to see what I built. I'm not saying its the best setup, but I am pleased with it. As with most of my mods, its not simple haha.
Battery has been moved to the trunk (boot if you like) to make room for a little "box" heat shield for the filter. The intake tube is real carbon fiber and crazy light and strong haha. Its actually a piece of brake ducting off a NASCAR race car that I have repurposed. Cut to fit, hole drilled for the one needed vacuum hose and a hole for the MAF sensor. I used the sensor mount off my old setup and epoxied it in place. Its not going anywhere ha. I also bypassed the heater hoses that goes to the throttle body to speed up warm ups, I live in FL, its not needed. I can't say that will do anything, but it is a popular thing to do in the car mod world so I figured why not. Makes sense that it could heat up the intake charge, and cold air is good air.
This might not be the best way but its what I built haha. I have more work do to on my car so I haven't been able to drive with this setup yet. It sounds awesome though haha. I also removed probably 40+lbs from the front of the car between the battery and metal tray that holds it. I'm also using a 15.5 lbs battery now, in the trunk. Weight relocation and reduction ha.
My next trick is going to be installing a mechanical trunk release in case the battery dies haha. Eventually I'll be running some ducting to my little "box" from the front bumper for more cold air in there. I have some more cool NASCAR carbon fiber parts for intake and brake ducts that i'll do some day.
PS, I don't care if you think the factory air box is better because that's how Jag made it.... enjoy.
Attached Thumbnails I built my "cold" air intake finally...at least look haha-before-after.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165123.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165142.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165037.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165000.jpg
I built my "cold" air intake finally...at least look haha-win_20150330_165019.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165246.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_164146.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_165108.jpg   I built my "cold" air intake finally...at least look haha-win_20150330_161659.jpg
Old Mar 30, 2015 | 10:14 PM
Pierrick584's Avatar
No need for mechanical trunk release. Just make sure you have somewhere to plug power In, I'm not sure I'd replicate. But nice job. Glad to see some people posting about performance and mods instead of another "diagnose my car" thread
Old Mar 30, 2015 | 10:25 PM
Naso--Lituratus's Avatar
Good job!!
Old Mar 31, 2015 | 06:24 AM
mrplow58's Avatar
Smile
Way cool!!! I took the easy way out, because I was afraid of what to do if my battery died. I am sure you can still hook up a positive tap, in your engine compartment for just that special occasion. My 928S has one.....Great job.....Mike
Old Mar 31, 2015 | 07:31 AM
Old Auto's Avatar
Looks well constructed. Where are you drawing air into the box from as it looks quite closed off (unless there is a bonnet vent)?
P.s Don't forget to top up your coolant level.
Old Mar 31, 2015 | 11:08 AM
wa3ra's Avatar
Looks good!
If you haven't, make sure you vent that battery/battery box! Jag beats the hell out of the battery, and they outgas pretty significantly!
Old Mar 31, 2015 | 04:54 PM
plums's Avatar
Nice bit of fabrication.
One thing though, have you vented the battery to outside of the trunk?
If not, take a look at how it is done on the XJ/XK models.
Old Mar 31, 2015 | 05:21 PM
Dr dome's Avatar
I took the cable that pops it from the inside of the car and extended a cable to behind the plate and put it through the black hole caps. I was also looking into a lock like the s types have. Maybe using the glove box lock so that the keys match. I don't lock my glovebox.
Hmmm any thoughts on this.
The Dr!
Old Mar 31, 2015 | 05:44 PM
Justink201's Avatar
The Dr!
my plan is to connect to that cable and run one to the inside of the car, probably to under the drivers seat. I'm going to hit up the junk yards to find something OEM for a trunk release. Many cars have them so it should be easy. I'll probably get a cable from there too now that I think about it.
Old Mar 31, 2015 | 05:56 PM
Justink201's Avatar
There is a decent triangular opening that opens the area where my box is in the fender well to the inner fender area. I doubt it will be pushing air into it, but I will be routing a 3in flexible NASCAR brake hose from the front bumper to my "box" eventually for that "ram air" of cooler outside air. My bumper is damaged so I'm not doing the ducting until I get my replacement painted and ready to go. Its crazy what you can find for sale on eBay by searching for NASCAR in parts haha.
Old Mar 31, 2015 | 06:18 PM
Justink201's Avatar
I'm using an AGM sealed battery and while its said that they do not off gas I'm still going to run a vent tube, just to do it. I was going to go look at my XK though so good call haha.
Old Apr 1, 2015 | 07:46 PM
X-TypeMentality's Avatar
Very nice work sir. Feels like I've been gone for a while! Lol I will for sure copy this mod! As I have with a few of your others
Old Apr 2, 2015 | 01:02 PM
Justink201's Avatar
Do so at your own risk haha. And post pics. Its always interesting to see how other people build things.
Old Apr 3, 2015 | 10:09 AM
Scricy's Avatar
Very nice.
Can you post a video with the sound of the car?
Thinking of trying this myself
xjrjag
Oct 24, 2024 03:09 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
cissdm
May 3, 2016 06:02 AM
explorer364
Sep 11, 2015 05:44 PM
1100me
Sep 7, 2015 06:26 AM
