"I didn't know my Jag did that!" thread
Old Jul 17, 2017 | 01:24 PM
  #81
Dell Gailey's Avatar
A bit more clarification = the sequence listed above needs to be done in all 4 windows to "supposedly" enable key fob global window up by pressing lock releasing and re-pressing for more than 3 seconds.
Old Jul 17, 2017 | 02:26 PM
  #82
yardbird's Avatar
Originally Posted by Dell Gailey
So I found a post of "reportedly" how to enable global up for European cars. I tried it for mine and still a no go, although manually using the key by locking, releasing and then holding to lock position again, will now raise windows left open.
Similar to resetting the auto up function. The window buttons have 5 positions = 2+, auto up, 1+, up, 0, neutral, 1-, down, 2+, auto down. Instructions were hold up button in position 1+, to fully close window, wait 2 seconds, release button for 2 seconds, again lift button to 1+ position for 4-5 seconds (but not longer than 6 which automatically cuts out power to preserve motor).
This is SUPPOSED to enable global close on key fob by locking, releasing and then holding lock fob longer than 3 seconds.
Didn't work on mine either. Just tried twice. But the key actually in the door to lock, then turn again and hold, closes windows and sunroof.
Old Jul 18, 2017 | 07:57 PM
  #83
So on another "fix-it" site, I found a Jag tech response to this question. It makes no sense to me, but here it is =
He said turn the key on and off 3 times quickly without starting car, it should enable "global" window up. If 3 times does not work, try 4 times.
Personally, this sounds like "voodoo", but here it is anyways.
Old Jul 18, 2017 | 08:09 PM
  #84
Thang Nguyen's Avatar
This sound dump, but I did not know the fold down rear seats knobs in the trunk until I saw them on my daughter's Ford Focus, by that time I already own third X-Types.
Old Jul 18, 2017 | 08:19 PM
  #85
One thing Jag put on information that annoying me is the message : "It's cold temp. out side" but I don't know how to disable it; When I go out to drive the car in the Winter, don't I know it was cold out side?
Old Jul 19, 2017 | 03:25 PM
  #86
It is an on or off feature that a dealer can disable. Drove Bimmers quite a bit, cold and ice reminder never bothered me.
Old Jul 25, 2017 | 06:57 AM
  #87
Namo's Avatar
Default Volume Control on steering
Was having issues with reducing my stereo volume from the steering control. As soon as i disabled my Automatic volume leveling, Problem solved.
Old Aug 9, 2017 | 04:54 PM
  #88
LeapingCat's Avatar
Originally Posted by QuintonChester
Not sure if anyone has noticed this, it's not really something it does, but it's cool, and I found it unique. On the fuel gauge, there is an arrow indicating which side your fuel door is on
I believe that on a lot of cars these days, if you look closely at the 'petrol pump' icon in the dashboard display, whatever side the fuel delivery hose sticks out indicates the side of the car that you refuel at.
Old Aug 9, 2017 | 05:44 PM
  #89
henry k's Avatar
DUNKS
Also if you lose power to the trunk/boot latch when it's closed.
YOU ARE IN ALL SORTS OF TROUBLE.
Especially Brit spec as we don't have the internal strap to open same from inside. "we don't tend to lock our kids in there"
One of the pathetic features of the car- no key operated manual unlocking.
My old 98 Ford Mondeo Ghia X /Contour had several features that are missing on the X type
I am NOT in trouble as I have a done the five cent fix.
It was one of the first modifications I did when I had read up on the forums about the situation.
So I will agree, most folks would be in trouble.
Owners of US models do not fully escape.
I have read - smash one of the rear lights to get access to the child emergency handle.
One US guy tried this
Details of his efforts.
A search of the UK forum will show a fully detailed step by step method.
My obvious suggestion is do the mod now just in case.
Old Aug 22, 2017 | 02:01 PM
  #90
On any sat/nav screen displaying the time in the upper right corner = if you touch the time display for a few seconds, it brings up the change time screen (normally found in the menu button(s) screen. A quick short cut to update or change (like US daylight savings time).
Old Jun 22, 2018 | 04:22 PM
  #91
PhilTrenbath's Avatar
If you hold the lock button on the keyfob with your windows down, it will lock the car and roll the windows up 8)
I think this was only on the 03 or 04+ models though, not completely sure. Or if you just turn the key while it's in the door to make it lock, and hold it for 2 seconds it will roll them up.
yay! My 04 2.0 DS does that 😎
Old Jun 25, 2018 | 02:46 AM
  #92
DUNKS's Avatar
Default Widows
My Xtype also does that! Be nice if the windows rolled down when unlock is held.
Old Jul 9, 2018 | 07:00 AM
  #93
andybsmith's Avatar
Originally Posted by Gold_04_X-Type
I wish my '04.25 did that!
My 2004 2.5 AWD does the same thing,press and hold the lock button on the key and the windows automatically close.
Old Jul 12, 2018 | 12:05 AM
  #94
Clackavosticus's Avatar
Subscribed
philwarner
Oct 4, 2024 01:37 PM
JarodL
Mar 7, 2024 01:39 AM
allenman85
May 10, 2021 03:11 PM
dcvickers
Sep 2, 2015 06:14 PM
XJsc-guy
Sep 2, 2015 11:43 AM
