Injectors swap
Hello.
I'm planning to swap EJDR00501Z with EJDR00504Z on 2.0D Has anybody done it before? If yes, do they works properly after coding. I suspect that they are interchangeable and 504z can be put instead of 501z as a single or full set. Different flow rates will be compensated by coding I think.
What's your thoughts?
If the injectors flow differently, if you did it as a set, I can see the computer being able to compensate for that . But, doing just one, I think you are going to have a cylinder that would be running rich/lean compared to the others. As for whether the injector would actually work, I will not speak to that.
