Injectors swap
Old Dec 17, 2024 | 12:46 PM
Nikolay's Avatar
Default Injectors swap
Hello.
I'm planning to swap EJDR00501Z with EJDR00504Z on 2.0D Has anybody done it before? If yes, do they works properly after coding. I suspect that they are interchangeable and 504z can be put instead of 501z as a single or full set. Different flow rates will be compensated by coding I think.
What's your thoughts?
Old Dec 19, 2024 | 09:05 AM
Thermo's Avatar
Veteran: Navy
If the injectors flow differently, if you did it as a set, I can see the computer being able to compensate for that . But, doing just one, I think you are going to have a cylinder that would be running rich/lean compared to the others. As for whether the injector would actually work, I will not speak to that.
Andreas Schmieg
Feb 10, 2026 03:57 AM
Mozambique
Sep 8, 2023 03:32 PM
Lachy
Jul 22, 2022 04:37 AM
XxMerlinxX
May 8, 2021 04:42 PM
M90power
Mar 24, 2012 08:35 PM
