Jaguar OEM bluetooth install
Hi, I just installed the OEM Jaguar bluetooth call module into my 2002 X-type, I installed the new connector to connect to both the cdc and bt module in the boot and also connected the antenna under the center console but when I press the phone button on my steering wheel or radio it still displays a "NO PHONE" message. Is there additional software or cables that need to be loaded or connected into the car or do I have to buy aftermarket
To install Bluetooth in a Jaguar X-Type, first determine if you need to pair an existing factory system or add an aftermarket one. For factory systems, find the car's Bluetooth menu, enable pairing on both your phone and the car, and enter the PIN (often 1313) when prompted.
https://www.jaguarforum.com/threads/...uetooth.82175/
Simonengines
Jan 9, 2016 08:00 AM
