Jaguar X-Type 2002 ignition coils from ebay
Old Apr 26, 2017 | 02:39 PM
girgisandy's Avatar
Default Jaguar X-Type 2002 ignition coils from ebay
I need to change my ignition coils and spark plugs on my Jaguar X-Type 2002 I was wondering if I bought it off of ebay from kind-auto-parts would my car still perform?
Old Apr 26, 2017 | 05:11 PM
JagV8's Avatar
Why change them? Serious question. Especially the coils.
Old Apr 26, 2017 | 06:56 PM
avern1's Avatar
+1 with jagv8. Unless you have misfires or more than 100,000 miles on the clock why are you changing them?
Old May 1, 2017 | 10:47 PM
girgisandy's Avatar
I do have a misfire in all of my cylinders I ordered the ignition coils from ebay and I ordered the spark plugs. Should I also change the valve cover gasket?
Old May 1, 2017 | 10:51 PM
girgisandy's Avatar
Both conditions take place I have misfire in all of my 6 cylinders and its at 110,000. I ordered the ignition coils from ebay and I also ordered spark plugs. Should I change the valve cover gasket?
Old May 2, 2017 | 09:44 AM
innzane's Avatar
I would change them if that far into the motor, would also have the upper and lower intake gaskets ready as well as the IMT gaskets, all will be in your hands during the process.
But a misfire on all 6 really points to other problems, but if you do the suggested above the other common causes are mostly on top of the engine.(unless bad cats)
To your og question, sure they will preform, chances are they will not outlast OEM stuff but they will work.
Please go ahead and add your model, mileage and any fault codes to your OP so others can try to help you.
Old May 2, 2017 | 10:46 AM
Alfadude's Avatar
It is highly unlikely you would have misfires on all six cylinders at the same time due to bad plugs or coils. They don't all go bad at the same time. Might be something else that is causing that or they might be old random stuff. What you might want to do is have the codes read, clear them and see what comes back and start there. Not that it is bad to change those things at that mileage and age, but chances are something else is at play.
Old May 3, 2017 | 06:53 AM
JagV8's Avatar
Be sure to check fuel trims are sane, too.
Qvhk
Mar 27, 2019 12:44 PM
Lenny B
May 1, 2017 12:16 PM
Mr_Nico
Mar 25, 2017 05:10 PM
genec
Feb 26, 2017 09:16 PM
scarbro2011
Feb 19, 2017 12:47 PM
