This legit?
Old Nov 1, 2008 | 10:22 PM
gupdah's Avatar
Default This legit?
i was looking through ebay and i stumbled upon this and this
Are these products legit? I doubt it but has anyone had any experience with them?
Old Nov 1, 2008 | 10:28 PM
gupdah's Avatar
Default RE: This legit?
found another product
http://cgi.ebay.com/ebaymotors/Parts-Accessories___Jaguar-X-S-XK8-XKR-Type-Gas-Saving-Fuel-Saver_W0QQitemZ150306307084QQddnZPartsQ20Q26Q20Acc essoriesQQddiZ2811QQcmdZViewItem?hash=item15030630 7084&_trkparms=72%3A543|39%3A1|65%3A12|240%3A1 318&_trksid=p4506.c0.m245
Old Nov 1, 2008 | 10:33 PM
Dennis's Avatar
ud
Snake oil..save your money, they are all BS..
Old Nov 2, 2008 | 01:46 AM
jvegas's Avatar
if there was a cheap and easy way to increase HP and MPG... don't you think Jaguar would have done it?
Old Nov 2, 2008 | 06:42 AM
BuckMR2's Avatar
BS
Old Nov 2, 2008 | 07:48 AM
Thermo's Avatar
Veteran: Navy
As the other guys pointed out, if these were as good as stated, don't you think Jag would have put these into the cars already?
As for the tornado piece (second one you listed), that is actually a part that would work if located in the correct spot. But, putting it upstream of the throttlebody kills all the effectiveness of the part (if anything, adds more restriction, therefore would reduce power). You would need to install a few of these (6 to be precise). You would need to install these at the inlet of the intake valves. That would then spin the air as it entered the cylinder, leading to better fuel mixing with the air, therefore more efficient burn. As for the computer plug in piece, it might work if you drive a particular way. But, odds are, you won't want to drive how that box would want you to. So, save your money. If you have to spend you money, there are other things that you can do to the motor to make it more efficient.
Old Nov 3, 2008 | 05:41 AM
racerx82's Avatar
Let put put it to you this way. To get a 30-40 hp gain cost roughly 500 bucks. There is nothing out there that will do it cheaper.
Save your money.
If you're looking for some hp gains on the jag...expect to spend $$$$$$$
Old Nov 3, 2008 | 07:37 AM
gupdah's Avatar
I knew this all was a scam, but i did not want to jump to conclusions, therefore I asked you guys.
Thanks for the response
creativebush
Sep 3, 2013 09:19 AM
mrlovt
General Tech Help
Jun 27, 2012 01:19 AM
dmsdvls3
Aug 19, 2010 03:37 PM
cincypix
XJ40 ( XJ81 )
May 13, 2010 12:52 PM
