Manual fan switch trouble
Old Aug 25, 2018 | 09:16 PM
Brevbolla23's Avatar
Default Manual fan switch trouble
I'm attaching a manaul fan switch on my 04 jaguar x-type and need a little help. I have the switch put together and since there is no fan relay, I'm not sure where to put the positive wire. Can I attach it to the module, if so, does it matter which prong?
Old Aug 26, 2018 | 03:21 AM
Steve M's Avatar
Curious as to why you need a manual fan switch; is the car overheating?
Old Aug 26, 2018 | 09:27 AM
astromorg's Avatar
Mmm. Sounds like you might be trying to cure a symptom rather than the cause?
The cooling fan module is controlled by a PWM signal from the ECM, not a simple 12v On/Off. (Fans are variable speed)
The alternative of splicing in directly into the main fan wiring would require a relay to handle the currents involved, plus some substantial diodes probably to prevent putting unwanted voltage back to the fan module.
Old Aug 26, 2018 | 10:33 PM
Dell Gailey's Avatar
Just do it right. Read #10 & 11 =
https://www.jaguarforums.com/forum/x...module-201955/
flynnaaron
May 4, 2024 07:14 PM
jdhooks1
Sep 6, 2014 11:50 AM
weisberg
May 13, 2014 10:12 PM
Japthug
Feb 25, 2014 11:54 AM
kennith13
Sep 10, 2013 02:49 PM
