Mileage for Clutch Replacement
Old Mar 1, 2011 | 10:54 AM
xtyperick's Avatar
Default Mileage for Clutch Replacement
I am considering purchasing a X-type with a manual transmission. What kind of mileage can I expect before I would need to replace the clutch?
Old Mar 1, 2011 | 11:02 AM
Tony_H's Avatar
Unfortunately it's completely a function on how the car has been driven. My guess at a range would be between 15k and 150k miles. My 03 has 60k and is working fine.
Old Mar 1, 2011 | 12:54 PM
sport30's Avatar
Banned
I agree.. this is a driver dependant question. I am at 266 000km and original clutch.
Old Mar 1, 2011 | 02:32 PM
Pete04xtype's Avatar
Before I bought my X the clutch was replaced by Jaguar. Purchased @ 19k miles and just recently traded in with 65k miles. Car was my DD for 4 yrs and the clutch still was in perfect condition when I traded it in.
Its all in how you drive it.
Old Mar 2, 2011 | 02:13 PM
xtyperick's Avatar
Thanks for feedback. I figured wear would be driver related. Guess I'll have to take my chances.
Old Mar 2, 2011 | 02:41 PM
benebob's Avatar
ud
I have 110k on mine and I would say it probably has a solid 40k left in it. Bought it at 90k and have used it for towing and spirited driving since. No issues with it but it doesn't seem to have "feel" of a new clutch at this point. Clutch kits aren't real pricey for the X type considering you'll be replacing the slave at the same time since it is internal. Much cheaper than replacing a slush box. If it feels okay and the car doesn't seem abused I'd go for it after proper vetting.
Old Mar 2, 2011 | 05:36 PM
Alfadude's Avatar
For what it's worth, there never seems to be a whole lot of posts on here related to clutch issues. I know the manuals are a lot less prevalent than the autos, but even so, it does not appear that the clutches wear out any faster than any other car or that there are any other inherent problems with them. If there were, I'm sure there would be enough posts about them.So, yeah, I'm with everyone else. All depends on who drove it. A clutch would be way down on the list of things that would be a concern on these cars. Good luck with your search!
Old Mar 3, 2011 | 10:57 AM
rothe's Avatar
86k miles on my car. Bought it used 11k miles and one year ago. I have no indication that clutch wear will be any worse than any other car. It *may* even be better.
These cars use a dual-mass flywheel. This is not a hugely common item in the manual transmission world. My understanding of it is that there's a mechanism in the flywheel assembly that will slip if you let off the clutch too abruptly in high-torque conditions. That lessens the shock to the clutch and the rest of the driveline. Just after buying my car - not during the pre-purchase test drive - I managed to hear this happening. It sounds like a ratcheting mechanism for a split-second, and might make you wonder if there's something wrong with the clutch. There isn't - it's the dual mass flywheel protecting the rest of the driveline.
And again, there doesn't seem to be an abundance of problems related to the dual-mass flywheel. Like others have said about the lack of clutch-related forum posts, the dual mass flywheel doesn't get much attention here either.
More info on dual-mass flywheels can be found here:
http://www.cdxetextbook.com/trans/cl...flywheels.html
And there's always Google:
http://www.google.com/search?q=dual+mass+flywheel
Old Nov 11, 2011 | 03:12 PM
disguay's Avatar
Has anyone actually investigated the difficulty of the replacement of the clutch? I am just looking at if I could do it myself with the proper lift and clutch kit
Old Nov 12, 2011 | 09:51 AM
rothe's Avatar
16 hour job, as per Alldata. They're usually pretty close, as those estimates come from factory documentation for dealer services.
You can download the factory manual from the very first link on this forum, and review the procedures. It's pretty involved.
Old Nov 12, 2011 | 04:54 PM
disguay's Avatar
Thanks for the all data info... Looks like that will have to be something that the shop will have to do
Forcedair1
Sep 8, 2025 01:57 PM
RoyLittle0
May 25, 2023 02:38 AM
cissdm
May 3, 2016 06:02 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
KarimPA
Sep 3, 2015 07:32 PM
