MTX folks- when do you shift?
For some reason I find myself wanting to shift really early, like 2 or 2.5K RPM. Seems like it clunks into 2nd no matter where I shift, but all other gears shift smoothly at between 2k and 2.5k. Sometimes 3rd will clunk if I don't do it at just the right moment. I almost never wind it out past 2.5K
Am I babying this thing? Where do you guys usually shift?
Pretty much same here. When the engine is warmed up, I may push it to 3000-3500 but rarely on gears lower than 3rd. Partly because if you accelerate fairly calmly yet go above 2000 rpm, it just makes more sound and gets a bit choppy if you don't keep your foot steady (lower gear, stronger engine braking if you lift), so I can just as well accelerate the same with a higher gear and get more smoothness.
Not sure about the clunking though. I seem to recall reading that there was an official way (technical service bulletin?) to smoothen the manual gearbox operation, but can't remember any specifics. I think it had something to do with the clutch as well.
I think I typically shift at almost 3K, at least from 1st to 2nd, but not because I baby it, that just feels normal for how I accelerate. I can't say mine clunks in any gear and I have no qualms when the mood strikes to accelerate more sharply or to wind the RPMs out to 5K or so. There are a lot of times I skip shift from 1st to 3rd and 3rd to 5th too.
I typically shift the car in a lower RPM range as well. (2-2.5K) Gear box seems a bit clunky in the lower RPM, maybe syncros don't like? A lot smoother shift in higher RPM. Would be nice to know if there is a service bulletin of shorts as I've just chalked this up to my driving style. (drive the car at 10%, 90% of the time, and 90%, 10% of the time. MPG's and Fun!!!)
Although, my car has always made squeak when shifting gears sitting in the driveway, thinking linkage.
When I first got the car I tended to change at about 2.5 to 3 thousand revs.. but now I have been driving her for a while I would say between 2.5 and 3.5 thousand.. if *really* honest it's more to do with the sound than necessarily the power when I change gear :-) I love the looks the car gets :-) :-)
This thread doesn't really apply to me, as I have a slushbox, but I REGULARLY J-Gate it out to 4.5k - 5k+ when accelerating onto a highway, or passing on highway, or driving on hilly backroads.
The 2.5 doesn't have very much "oomph," so it takes some winding out to her moving.
Around town, I let the auto do its thing.
Shifting into second is always a bit jarring for passengers but I've found it smoother running up to 2.5-3.5 range and going to third. My normal shift point is above 3k because that is when the smile forms every time.
I'm no expert... perhaps it's just wishful thinking...
Out of curiosity, when your T-Case blows and you have to replace it, are the replacement parts more robust/reliable than the original parts?
Thanks.
