My 02 xtype engine light came on then off
Old Jul 4, 2011 | 04:36 PM
bruin27's Avatar
Default My 02 xtype engine light came on then off
So yesterday I start my car to drive to work and the engine light came on.. I didnt notice any difference in the drive to work just that the light was on. After work I ran a few errands and when I was on my way home the light wasnt on when I started my car. Weird.. I know im due for an oil change and my coolant is somewhat low and the temp was around 100 here in california... any suggestions if I should look into this?
My car is an 02 x-type 2.5, 5 speed.. has 68k miles
Old Jul 4, 2011 | 09:35 PM
JDP's Avatar
JDP
Sounds like a Vacuum Leak, have you replaced your INT valve gaskets?
Old Jul 5, 2011 | 08:58 PM
bruin27's Avatar
honestly all ive ever done is change the oil on my jag.. never had any issues at all until now.. i did look under the car and the oil pan looks like it may be a little wet.. whats the cost on the valve gaskets replacement?
Old Jul 6, 2011 | 07:50 AM
JDP's Avatar
JDP
The INT Valves are on the intake, they would not cause an oil leak. If you have a 2002 you probably still have the yellow gaskets which were prone to leaking the new o-rings are green. The O-rings themselves are pretty cheap under $20.00 for both. The INT valves are those black plastic caps on the end of your intake. I replaced them myself it only took about 20 min.
My car exhibited the same symptoms when they started to go bad and it had around 75k miles. Get a code read and see if you have any stored codes. If it is running lean on a cylinder bank than it is most likely an INT O-Ring
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
