my retrofit touchscreen vs my doubledin,lots of info
Old Apr 27, 2016 | 06:55 PM
  #121
dennis black's Avatar
it was a while ago i did this ill take a look
Old Apr 28, 2016 | 06:55 AM
  #122
Jpine1980's Avatar
Yeah, I drilled that hole and got it installed, just not sure wiring. I think the positive is the yellow wire from nav tool but ground is the issue. Do I run the ground to chasis, or to the gray E-break wire which is met for ground and required for screen activation but I have bypassed the e-break wire because want screen to stay on. Thanks for the info.
Old May 12, 2016 | 10:49 AM
  #123
hutchthis's Avatar
Dennis,
I have an 07 x-type wagon with nav and cd player. I want to solder line input like you, but I cannot see with enough clarity in any of your pics what the exact points are on the pcb and what wires are soldered where. Can you upload a more detail photo? Or just label this photo. Thank you and good work.
https://www.jaguarforums.com/forum/a...av-pinouts.jpg
Old May 12, 2016 | 06:31 PM
  #124
i should have it some where in my files ,ill take a look
Old May 15, 2016 | 02:24 PM
  #125
heres my LEXUS GS350 finished then ill be working doing a write up for my x-type,so you all can give it a try ,i would of done a write up along time ago but i wanted to do it right so you guys have no problems
Old Feb 19, 2017 | 07:21 PM
  #126
my vid its old
ill be showing my new set up ,with custom interior
Old May 15, 2017 | 06:06 AM
  #127
Clarence Johnson's Avatar
Default Jaguar S type retrofit...
Originally Posted by jagtrooper
Wow, fantastic job. I wish that i had the skills to do this to my 2005 s type r
Hello all I'm new here, actually I have done something similar to my 2000 Jaguar S Type but instead I went with a larger display... 10.1 inches to be exact... It came with no navigation but now has great 3D maps, kodi, tunes of local and internet radio, wifi enabled, tv, front and rear camera, siriusxm, and many more I also changed my stock gauge cluster to a virtual gauge cluster with the ability to see my navigation among my Virtual Gauges as well as my music selection and play status... Also voice command control I will eventually post my videos you may also go to my YouTube page and view a few of my early progress videos.... Thanks
Old Aug 27, 2017 | 06:03 AM
  #128
charles T's Avatar
Hello I am new to this forum. I have an 2005 XJ8L and I love Dennis setup but also realize this topic is old. Is that the latest upgrade that I can do and is it this product that your using
Navinc.nl
Thank you
Old Aug 28, 2017 | 03:08 AM
  #129
charles T's Avatar
I think you can use the parrot set up for Bluetooth
There's a lot of options
I have my multimedia set up almost done I'll post a video and pics in a few days, my stock sat nav has now YouTube Hulu Sirius xm HBO go , and many more options, I can also mirror my Samsung Galaxy 5, on the screen
heres a little taste
Attachment 157359
Attachment 157360
My Question is will this work on my 2005 Jaguar XJ8L
Old Nov 6, 2017 | 12:45 PM
  #130
Thang Nguyen's Avatar
Denis Black! I'm looking for another X-Type or XJ, some of them had Nav. with touch screen, it's a nice feature but I have read that once the Jag. touch screen went out you lost control other features such as climate control, you have to replace with OEM unit and that's very expensive and that keep me hesitate to get a car with touch screen. How do you go about this issue to prevent the touch screen from went out or how to keep the other control features if it does went out? Is replace with after market work better and last longer? I (am an old scoot) don't need a fancy feature, just Nav. and the original control features, are there any plug and play unit after market Thanks
Old Nov 6, 2017 | 07:32 PM
  #131
dont worry about the nav screen going out there are easy cheap fixes once you get the nav screen you can do things like this
Old Jan 5, 2018 | 04:07 PM
  #132
nazoben's Avatar
Default LoL
How you control your climate? Can you explain what you do.
Old Jan 5, 2018 | 07:48 PM
  #133
climate works like normal, when you hit the nav button it goes into android mode ,ill post a video
Old Jun 21, 2020 | 11:01 AM
  #134
new set up coming
vinny jones
Apr 28, 2021 08:14 AM
vinny jones
Oct 5, 2015 07:20 AM
Wolfy
Sep 11, 2015 06:27 AM
neckstrap
US Western
Sep 10, 2015 10:44 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
