Mystery solved: remote control sometimes does not work
I am reporting my experience in case someone out there has a similar problem.
I had an intermittent problem with my remote control often failing to open or lock the doors. By luck I discovered the following:
When you remove the ignition key, a spring-loaded metal flap closes the slot. But if the flap gets stuck in the open position the remote control is ineffective. A drop of oil is all it needed.
I've been putting off fixing that very problem since late last year. I had myself convinced it was a problem with the driver's door latch.
Thanks to your post, I just fixed mine in about 30 seconds!
I had an intermittent problem with my remote control often failing to open or lock the doors. By luck I discovered the following<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Blackweb Universal Remote Codes:
KittyVet
May 31, 2020 11:57 AM
sweatyfox
Jan 19, 2017 01:10 PM
