Need help cleaning exhaust tip
Old Mar 27, 2013 | 03:46 PM
alvinsjag's Avatar
Default Need help cleaning exhaust tip
What is the best way to clean my exhaust tips?
What kind of exhaust tips do I have? Stainless, chrome, aluminum?
Suggestions on what to buy please
Attached Thumbnails Need help cleaning exhaust tip-1zfhl6c.jpg   Need help cleaning exhaust tip-239ykm.jpg   Need help cleaning exhaust tip-2w4moi9.jpg
Old Mar 27, 2013 | 03:55 PM
Thermo's Avatar
Veteran: Navy
Alvin, as I recall, the factory tips are just chrome tips. I would recommend getting your hands on some 3M Perfect-It III (Grade 2). That should do you wonders with that. A little on the expensive side, but this product will work on all of your car (body, glass, chrome, wheels). I love the product. You use this stuff and then wax your car, it will look practically new as all the fine scratches will be gone.
The other product you may want try is NevrDul. It is a cotton ball soaked in a polishing compound. Good stuff. Takes a little bit of elbow grease, but I have seen it pull off some miracles. It is cheaper than the 3M stuff, but also is much more limited than what the 3M product is.
Old Mar 27, 2013 | 05:59 PM
alvinsjag's Avatar
Thanks Thermo for your reply, I bought and tried NevrDul.
Here are some of the results.
Any other suggestions?
Attached Thumbnails Need help cleaning exhaust tip-2j4aubt.jpg   Need help cleaning exhaust tip-n51udl.jpg
Old Mar 27, 2013 | 08:45 PM
kccode1's Avatar
The best chrome cleaner I have found is white diamond. Website
Mine were about as bad as yours but had more carbon. They won't come brand new. I used a fine emery cloth to get them as good as I could but they are pitted.
Old Mar 27, 2013 | 09:08 PM
Look much better...
You could try 0000 wire wool with a little elbow grease......Once you've done this a few minutes with some Autosol or similar should bring them back as new.
Old Mar 27, 2013 | 10:56 PM
Thermo's Avatar
Veteran: Navy
ALvin, get your hands on some rubbing compound and then rip some terry cloth into 2" wide strips. PUt some rubbing compound on the exhaust tip and then wrap the terry cloth half way around the tip. From there, push-pull the terry cloth back and forth across the exhaust tip (like you were polishing some shoes). Work up and down the tip and then you can also work around the tip to polish the sides too. The harder you pull on the terry, the more cutting that you will do. Just don't pull too hard as there is a rubber mount near the end of the exhaust system and I would hate to see you rip the mount.
Old Mar 28, 2013 | 02:55 PM
WayneCountyBill's Avatar
Default Take a Look At My Behind...
I use Brasso. I clean them about every other wash. I use a papertowel to apply, rub, buff and then another papertowel for a final buff. Good luck!
Old Mar 29, 2013 | 10:58 PM
jaguarcraver's Avatar
I would first take a couple of damp microfiber cloths and dampen them. Then I would gently go around the tips, changing or rinsing as they got dirty to remove the gritty stuff. Then I would dry them off.
Next, I would take some Wenol or Semichrome and rub it on thick. Let it sit for 30 minutes or so. Go back and wipe it off to aid in removing the rust. Then I would work the metal polish into a clean microfiber cloth and proceed to rub the tips briskly.
By removng the grit and rust first, This may prevent those fine scratches that sometimes reduce the sheen.
Hope this helps.
silkcat
Jan 18, 2025 04:29 AM
aholbro1
Dec 29, 2024 06:46 PM
Jandreu
Jun 30, 2022 03:10 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
jaaag
Sep 11, 2015 12:53 AM
