In need of some advice!
Old Nov 12, 2015 | 11:21 PM
Dan Hanning's Avatar
Default In need of some advice!
Hi all! First post so let's see how this goes!
Have an X type 2.5 v6 sport AWD and have recently had some issues, first it refused to start and the fault code indicated a faulty fuel rail pressure sensor. Replaced that and she still refused to start. The code that now appears is ECU defective. But is it as simple as replacing ecu and transponder? In serious need of help and wisdom. Thanks Dan
Old Nov 12, 2015 | 11:43 PM
Scricy's Avatar
not quite as easy.
you need to "pair" the ECU with the car.
Old Nov 13, 2015 | 02:28 PM
Originally Posted by Scricy
not quite as easy.
How us this done? Is it complex?
Old Nov 13, 2015 | 03:48 PM
avern1's Avatar
In order to be of the best help we need to know the codes. It is unlikely that one day the ecu is good and the next day it isn't. There are quite a few things that affect the ECU. Fuses, wiring, connectors and sensors. It takes a bit of troubleshooting to decide the ECU is toast.
Post the codes and we can see how we can help.
Old Nov 13, 2015 | 07:58 PM
Paulc732's Avatar
With any electrical problems on the X-type
first thing to check is the battery,
our cars are very sensitive to a weak battery. all the computers need 12V not 5V or 3.3V like other makes.
fully charge your battery and have it load tested.
Word of caution our cars also do not like getting jump started.
hope this helps.
Old Nov 14, 2015 | 02:18 AM
When plugged into the computer all that came up was ECU defective. No code as such. You'll have to bare with me I'm not used to cars with all this technology 😕.
Thanks Dan
Old Nov 14, 2015 | 02:19 AM
hope this helps.
Have fitted new a new battery and ECU defective stI'll appearing.
Dan
Old Nov 14, 2015 | 09:04 AM
Scricy's Avatar
first you will need to buy an ECU. same year and same engine as your car.
try the junkyards or part cars because as you might know already ECU's are quite expensive.
plug n' play... see what happens.
if this does not work you will have to go to a service or mechanic who is familiar with ECU's or car software issues. he should be able to pair your car with the new ECU via OBD and specialized software.
i had the same issue but not on my jag. it was on another car... had to change the ECU.
Old Nov 14, 2015 | 11:50 AM
I have bought an ecu, transponder and clocks so fingers crossed.
Thanks for all the help will keep updated.
Dan
1960apache
Nov 15, 2015 07:49 PM
Muttley
Nov 14, 2015 08:58 AM
lee101
Nov 10, 2015 05:14 PM
XxSlowpokexX
Nov 9, 2015 03:55 PM
coldpad1
General Tech Help
Nov 9, 2015 02:10 AM
