Newbie with question about these Dam Lug Nuts!
Old Jun 22, 2010 | 07:53 PM
87vertgt's Avatar
Question Newbie with question about these Dam Lug Nuts!
Howdy Gents! good to be here!
Lemme ask ya....can i swap out the stockers with one of these?
thanx
http://www.oreillyauto.com/site/c/se...22&keyword=lug
Dorman - Wheel Nuts
Part Number: 611-044
Line: DOR
  • AutoGrade
  • 5/8-18 x 21/32"
  • Hex Size: 1-1/16"
  • Open Nut
  • 90 Degree Seat Angle
  • Limited Lifetime Warranty
  • Universal Product
or
Dorman - Wheel Nuts
Part Number: 611-049
Line: DOR
  • AutoGrade
  • 3/4-10 x 3/4"
  • Hex Size: 1-1/4"
  • Open Nut
  • Universal Product
I appreciate any feedback
Old Jun 22, 2010 | 07:54 PM
87vertgt's Avatar
oh...Unit is a 2004 X 3.0
Old Jun 22, 2010 | 10:15 PM
H20boy's Avatar
You have the same size (at least thread specs) as the s-types, and those guys have found a few excellent replacements. You need to check your shaft length and diameter, make sure you get the right dimensions, but if you can show they're identical to the s-type's, those members have done all the legwork for you already.
Drop over there and search for 'lug nuts'. Gluck!
Old Jun 22, 2010 | 11:18 PM
exexpat's Avatar
Are you replacing them on stock wheels? I had factory sleeved lugs on my factory BBS wheels, and aftermarket lugs would not have worked. With aftermarket wheels, you need aftermarket lugs.
Old Jun 23, 2010 | 12:58 AM
87vertgt's Avatar
thanx for the responses's boyz.........
No flashy rims here...just stock....just trying to avoid being stranded and having to get a tow ya know.....
Old Jun 23, 2010 | 09:22 AM
MattSteele's Avatar
I don't get it...why do you think the stock lug nuts would leave you stranded?
Old Jun 23, 2010 | 10:18 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
When I bought our Jag, there was a missing lug nut. I went to an O'Reilly's to order one, and in spite of numerous phone calls, they claimed to have nothing that met the specs.
I would be quite wary of this one - unless they obtained a new supplier and new stock, it just might not fit.
Old Jun 23, 2010 | 02:34 PM
87vertgt's Avatar
cause i work at a tire shop and deal with those lugnuts being stripped down
Old Jun 24, 2010 | 08:27 PM
MarkC's Avatar
I've had to replace two lug nuts and the corresponding wheel studs on my X-type thus far as they seized for no apparent reason (I always use a torque wrench). I replaced then with these from NAPA...
Wheel stud P/N BK6414225 $1.83 each
Wheel nut P/N BK6414244 $2.51 each
These parts are listed for a 2002 Lincoln LS. The studs are a tiny bit longer than stock, but otherwise identical. The lug nuts also fit perfectly, but are slightly smaller in diameter at the top of the hood (i.e., the top of the decorative stainless steel cover, which is purely cosmetic). If you want all five lug nuts on a wheel to match perfectly, just replace them all!
Old Jun 24, 2010 | 09:17 PM
mohrd's Avatar
87vertgt it's worth the dough to get a one piece chrome nut (no more tin cap) like these http://cgi.ebay.ca/20-JAGUAR-LUG-NUT...item5ad7486c81 as long as that's what your current one with the washer looks like.
Old Jun 24, 2010 | 10:52 PM
PreJag's Avatar
morhd +1
The stock lug nuts are a pain in the *ss if the SS skin happens to spin on the nut.....been there. They are a mag type nut, but Jag had to make things difficult by using a unique shaft length and diameter.....hard to find, but yeah, Ebay is your best bet. I got a set of solid chromes for $75.
Old Jun 25, 2010 | 08:54 AM
87vertgt's Avatar
thanx for the response!
we dont have a napa...just a Oreillys...
I looked up 2002 Lincoln ls and found the lug nuts
Dorman - Wheel Nut
Part Number: 611-100
Line: DOR
  • AutoGrade
  • Specialty Nut
  • M12-1.5
  • Acorn (1 Piece Construction)
http://www.oreillyauto.com/site/c/se...002&vi=1387177
Question? Can I used these lugs without swapping the studs?
Thanx mang !
Old Jun 25, 2010 | 08:56 AM
87vertgt's Avatar
Originally Posted by PreJag
morhd +1
thanx for the link bro.....I would jump on it but I need them now!
Old Jun 25, 2010 | 10:46 AM
H20boy's Avatar
87, yes...no need to change the studs at all.
Now, go get'em. (well call first, they may not have them in stock)
Old Jun 25, 2010 | 02:14 PM
RobGardnerBlack's Avatar
Sound advice there - I have Dorman's on both the STR & X-Type having paid $88 for a set of 20. They are fine however, the plating appears to be not that durable. Just the opinion of someone using them for around 5 months now.
Old Jul 7, 2010 | 03:19 PM
Mistahchin's Avatar
I have a 04 Vanden Plas... got a set of 4 solid chrome for $6.50 from pepboys. I plan on replacing all.
Old Jul 7, 2010 | 04:26 PM
Mistahchin's Avatar
http://www.whtknight.com/cgi-bin/prodtype.cfm?subcat=19
Neil1664
Jan 20, 2022 08:59 PM
TheWarlock
Jun 25, 2020 05:24 PM
iownme
Sep 11, 2015 02:57 AM
ferraripete
Sep 10, 2015 01:24 AM
jfitzoz
Sep 7, 2015 04:28 AM
