No amber light (mil), cruise control not available, car cuts at 3000rpm
Old Oct 16, 2017 | 11:34 AM
bandenere88's Avatar
Default No amber light (mil), cruise control not available, car cuts at 3000rpm
hi everyone
my 2003 x-type 2.1 v6 petrol doesn't show any codes nor engine light (amber light) but it displays "cruise control not available" and it wont pass 3000rpm. At idle and from 0-3000rpm the acceleration is precise and smooth.
already did breather hose
Old Oct 16, 2017 | 11:44 AM
I also would like to add that we tested the cruise control system itself at the jag dealer but it looked in good condition.
Old Oct 16, 2017 | 12:07 PM
Alfadude's Avatar
What might be happening is you have a Chassis (C) code and the reader you are using can only read P codes. Based on the Cruise Not Available message you see a good place to start is a bad wheel speed sesnor. That would show up as P1145, 55, 65 or 75 depending on which wheel it is associated with. Not the only possible cause, but a common one.
Good luck. Hope you get it sorted soon and please let everyone know what the cause turns out to be.
Old Oct 16, 2017 | 12:42 PM
First of all thanks a lot @Alfadude for your help,
now that you say so, our last attempt was the abs.
In facts we noticed that unplugging the abs both problems seemed to disappear so
we drove for a week with the abs unplugged with apparent success(no "cruise control not available" message nor 3000rpm limit) so we bought and installed a sencond-hand abs, but unfortunately, both problems showed again now even with the abs unplugged. XO
that's why my next attempt is probably going to be reluctor rings and sensors
we going to keep everyone updated until the car is fixed
Old Oct 16, 2017 | 12:45 PM
may I also ask you for other possible causes following this direction?
Old Oct 16, 2017 | 01:20 PM
Alfadude's Avatar
Could also be damaged wiring to the speed sensor(s). Most of the time that would solve the problem.
Old Oct 16, 2017 | 01:29 PM
Thumbs up
thanks a lot i'll keep you updated
XFR_Gold
Sep 2, 2015 12:24 PM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
kmeh7
Jan 15, 2015 11:12 PM
85_305
Apr 1, 2010 09:29 PM
jimmycruz99xjr
Jan 1, 2010 10:58 AM
