No Radio Information after replacing battery
Old Dec 11, 2008 | 09:33 AM
keitho64's Avatar
Default No Radio Information after replacing battery
I had to replace the battery in my car and since then I cannot get the radio detail on the display. It used to show the song, artist etc but now nothing. In reading the manual it suggests the signal is not strong enough. I live in Chicago and it always used to work. Does anyone know if there is a special way to reset the radio or is there some stupid configuration.setting I am missing? The radio/CD all work perfect but I do not get the information display any more.
2004 X-Type 3.0 Sport
Old Dec 11, 2008 | 10:11 AM
Dennis's Avatar
ud
Default RE: No Radio Information after replacing battery
You need the radio unlock code (4 digit) It should be with your OM stuff, look for a credit card size card (Green) that has the code...The other thing you can do, is go to the dealer in person and they will find the code for you..but you must be in person..at least my dealer requires that.
Old Dec 11, 2008 | 12:34 PM
Kevin93940's Avatar
I forget the initials exactly - but there is a button on the audio unit labeled "RDMB"? or something that switches the text display on and off. This setting my have been reset when you disconnected the power. If the radio is working, press and hold the RDMB button and the text display may come back.
If the radio and CD player are working OK - I don't think your unit is locked.
Old Dec 11, 2008 | 02:59 PM
keitho64's Avatar
Thank you for the feedback, here is what I found out so far.
It does not appear that the radio is locked since it all works. Also I cannot find a way to enter an unlock code and my owners manual does not cover this.
According to the manual I need to get the radio into RBDS mode - per my manual I do this by holding the TA button more than two seconds (prior to the battery replacement this worked). Upon holding the button for at least one minute nothing happened
It also says I can hold the PTY button in, but that does not work as well
If I press the MODE button I am prompted for the usual - Bass, Treble, Balance and Fade.
If I hold the MODE button for an extended time it takes me to the clock set. I am never presented with the TA Volume and the other menu items.
It is almost as if the TA and PTY buttons no longer work. I will add that A-MEM buttom works fine. Since this one does I doubt it is a hardware problem with the button.
I am going to pull the fuse for the radio and let it lose its' memory and then try reprogramming.
It is amazing how accustomed I became to seeing the name of the song/artist/radio information. I feel like I am listing to the radio naked.... This is not a major issue but more a nuisance. I am sure when I figure it out I will feel like a fool who missed the obvious.
Old Dec 11, 2008 | 10:26 PM
Kevin93940's Avatar
Keith -
Keep us posted on your progress. The radio is known to have gremlins. Mine works perfectly - but one night I got back into the car - and although everything was working - I had no audio output - and the unit had lost its Bluetooth pairing to my phone. All I did was park the car for an hour.
I got home, parked the car in the garage for half an hour - and when I started the car again - the audio was back. All I had to do was restore the Bluetooth pairing.
It's never happened again, and I have no idea why ithappened the first time.
Old Dec 11, 2008 | 11:50 PM
jvegas's Avatar
will the artist and song read out thing work for the acm? for my ipod?
Old Jan 27, 2009 | 10:28 AM
keitho64's Avatar
OK a little more information. I disconnected the battery for an overnight stint. When I connected everything back the Radio does work but still no display of the information. It seems as is the buttons TA and PTY do not work but the A MEM does. I am going to pull the radio out of the car this weekend and see if there is an issue with the buttons. I can hold them down for a long period of time and nothing happens, I can press the quickly and nothing happens. The only problem is the lack of radio information being displayed and the automatic volume does not work. Time will tell.
If anyone has had any relavations since this original post let me know.
Old Jan 27, 2009 | 02:27 PM
Real_Tech's Avatar
Turn ignition to on or start the engine, press the AM/FM button and eject button at the same time. The display should now read SET UP MODE. The number keys will select and toggle between selections. Just make sure you don't set the radio to EURO because AM will no longer be available and you WILL NEED a code if the radio is in EURO mode. One note though the radio doesn't usually lose its mind unless the battery has been disconnected for an extended period of time. I have had batteries disconnected for 2 or 3 days with no trouble, even presets are usually still there.
Old Jan 27, 2009 | 05:21 PM
keitho64's Avatar
Real_Tech if you are ever in the Chicago area let me know, I owe you a beer, or three. [sm=icon_cheers.gif]
Mine was setup as USA No RBDS, I hit 1 on the number pad and it went to USA RBDS. I hit AM FM and lo and behold all the details are there. THANK YOU!!!! Are there any other configuration setting on the radio that are enabled via this 'feature'?
Old Jan 27, 2009 | 06:24 PM
Real_Tech's Avatar
Nothing of any importance. I think the level of the auto volume adjust feature is there and if you have an early model with cassette the self cleaning feature can be turned on and off. Just do it again and press different numbers to see exactly which features are on your particular radio. You would be surprised at how many X-type radios I've had to remove from EURO spec in the dealer. I think people just experiment and the next thing you know they are in EURO and cant figure out why the AM doesn't work even when the display says MW or LW instead.
I used to go to Chicago a lot but they closed the Jaguar school there so I go either to Toronto(cannonball rules!) or New Jersey.
Old Jan 27, 2009 | 06:42 PM
Size:  6.3 KBName:  AudiX6JYM-2.jpg
Size:  6.4 KBName:  T15ESSST101-1.jpg
Size:  9.9 KBName:  tshirt03-2.jpg
Good info there Real tech
I'm gonna FAQ this as there is a bit of info and it may help future members with similar probs.
FAQ'd
Jim
Old Jan 27, 2009 | 07:24 PM
Jamey's Avatar
ORIGINAL: Real_Tech
WOW! I had NO idea. You rock RT.
Old Jan 27, 2009 | 08:21 PM
keitho64's Avatar
Real_Tech - Sorry you don't get to Chicago, but if you ever do let me know, I will buy you a beverage of your choice.
Old Jan 17, 2023 | 07:12 PM
bmaule's Avatar
Default Awesome
Really wonderful and useful information. It worked for me.
jehart49
Sep 12, 2015 05:36 PM
Sprayall
Sep 3, 2015 07:49 PM
tony bosco
Sep 1, 2015 02:06 PM
Thia
Sep 1, 2015 10:36 AM
Jandreu
Aug 29, 2015 07:31 PM
