P0430 Help
Old Aug 9, 2013 | 06:50 PM
ddasilva99's Avatar
Angry P0430 Help
Hello,
I need your help. I purchased a 2002 X-TYPE v3.0 many years ago for my mom and it is up for (Ontario) emissions testing due by the end of August. The car has a check engine light and it is reporting P0430 catalyst below efficiency bank 2. The local Jag dealer quoted $1800 to fix the issue by replacing the cat. What a rip off!
My mother cannot afford a $1800 repair but she needs to pass the emission test. How do I get rid of the code so that I can pass the emission test? Should I get O2 simulators?
Lastly, is this an O2 issue or cat issue or something else?
Any help is appreciated with this issue. Thank you in advance.
D
Old Aug 9, 2013 | 08:17 PM
DPK's Avatar
DPK
Only fix for cat efficiency codes is replacement of the effected cat..
But before you go out on limb..check these possibilities first.
  • An oxygen sensor is not reading (functioning) properly
  • There is an exhaust leak
Old Aug 9, 2013 | 11:59 PM
Dr dome's Avatar
if you are somewhat handy. You ca buy one off ebay. There is a guy who makes them for 250 to 300 US. They are a perfect match to OME and a fraction of the cost.. If you are looking to get one. PM me and I will find the guys name.
Thanks and Good Luck!
The Dr!
Old Aug 10, 2013 | 06:36 AM
Jac's Avatar
Jac
Originally Posted by ddasilva99
Hello,
D
This should get rid of your CEL. Oxygen Sensor HHO Extension Hydrogen Spacer Test Pipe O2 M18 x 1 5 Thread Size | eBay
Old Aug 12, 2013 | 10:25 AM
akubeta's Avatar
Jac:
Would you be able to shed some light on how to install this spacer?
Old Aug 12, 2013 | 01:17 PM
Jac's Avatar
Jac
Originally Posted by akubeta
Jac:
You have to remove your O2 sensor. It's much easier with the correct socket which you can buy at a reasonable price. Screw in the spacer, then screw in your sensor. Done! These have worked for me. I replaced an O2 sensor and the CEL came back on after about 50 miles. Then I put a spacer on later and CEL never came back on. That was about 2500 miles ago.
Old Jan 6, 2016 | 02:07 AM
Neville Hobbs's Avatar
Default Please update this thread.
Can you guys please update this thread. I have the same P0430 problem and would like to know how you solved the problem.
Thank you.
Old Jan 6, 2016 | 02:33 AM
JagV8's Avatar
Generally you check the cat and find it's bad so replace it. If it's OK then suspect the O2 sensor(s). Etc. See what Jaguar say about the code!! (I know, so old-fashioned to read the documentation.)
Old Jan 6, 2016 | 06:01 PM
Jac's Avatar
Jac
No, generally you check your O2 sensor first. http://www.jaghelp.com/2014/04/p0420...ar-x-type.html
Old Jan 10, 2016 | 12:21 PM
JagV8's Avatar
As I said - read the Jaguar documentation!
It has more about O2 sensor problems than anything else...
juwels365
Dec 7, 2018 02:29 AM
daxter1987
May 1, 2012 08:31 AM
dia_cero2002
Sep 23, 2011 10:45 AM
mtfife
Jan 21, 2011 05:41 PM
Tracy
Jul 13, 2009 11:47 PM
