p1000 code... obd not ready?
Old Aug 2, 2013 | 07:25 AM
bharvey622's Avatar
Default p1000 code... obd not ready?
Hope everyone's doing well this Friday... Here's what I have 2002 xtype 2.5 standard.. Check engine is on.. Abs aswell.. P1000 code comes up with bluepoint scanner. Ran emissions test came back as follows: catylist monitor - NR .... Evap system monitor - NR....02 sensor monitor - NR.... . O2 sensor heater monitor - ready. Any suggestions
Old Aug 2, 2013 | 07:57 AM
You will always get either:
P1000: OnBoard Monitoring Tests not completed since last memory clear
OR
P1111: OnBoard Monitoring Tests completed
As you complete the required drive cycles, the P1000 will be replaced with P1111.
With the CEL showing, I'd expect to see other Pxxxx codes stored or pending ........
Old Aug 2, 2013 | 02:53 PM
bharvey622's Avatar
So what's the correct drive cycle to get these test to complete?
Old Aug 3, 2013 | 06:27 AM
JagV8's Avatar
See codes PDF in JTIS as it details it.
However, faults can prevent getting as far as P1111 and occasionally can even prevent codes being flagged.
What codes did you have before you cleared them (thus leading to P1000)?
Old Aug 3, 2013 | 11:15 AM
bharvey622's Avatar
Not sure.. When I bought it I had to call jag for the correct pin number BC the stereo was locked.. A shop scanned it for me and NO codes came up even with the light on. So he shut the light off only for it to come back on. I bought a bluepoint scanner and that's kinda where I'm at now.. I tried the drive cycles this morning but they are all still Not Ready except OH..
Old Aug 4, 2013 | 02:36 PM
JagV8's Avatar
MIL should be off if no codes (P1000 isn't a fault code, nor is P1111). If it's on, you have codes. Maybe an OBD tool playing up.
With no codes, MIL should self-test at ign on and then stay off.
Old Aug 4, 2013 | 04:22 PM
bharvey622's Avatar
Default Update Status
hey guys its been a long weekend lol.... so a little update.. all of the monitors have become ready Except "O" and "CC".. and it was actually because i left the ignition on the #2 spot for a few minutes to plug scanner in and when i checked most monitors are ready..and they have all stayed this way so far today.. im really becoming lost here
Old Aug 4, 2013 | 05:22 PM
The P1000 / P1111 is not the main issue here.
When the MIL is illuminated, there should be other code(s) which will indicate the underlying fault. If your code reader isn't showing any, you need to get connected to a scantool known to interface with your X-Type.
Old Aug 5, 2013 | 06:04 AM
bharvey622's Avatar
Someone on here posted that the memoscan was a good scanner for xtype.. I picked one up online so I will wait for it to come in.. Also the abs light is on and say DSC system failure.. Although the scanner will read abs it says the car won't support it.. Could that have something to do with the CEL? Also thanks for all of your help!!!
Old Aug 6, 2013 | 09:52 PM
bharvey622's Avatar
Update: I borrowed a friends snap on global scanner and viewed the live engine data... All monitors are ready except "c" and "o" still... But bank 1 sensors were going crazy with reads.. They were as low as -1500s to + 1500s.. Could these two be the culprits? And if so is there an inexpensive sensor to replace them?
Old Aug 30, 2013 | 04:05 AM
JagV8's Avatar
Stop. Read the codes. If you have the MIL on then you DO have codes. Ignore the monitors until after that. Don't swap parts.
Old Aug 31, 2013 | 07:58 AM
bharvey622's Avatar
Ya it came up with a c1165 code and come to find out the tone ring is gone. So I'm waiting for that to come in.
Old Aug 31, 2013 | 08:24 AM
JagXV6's Avatar
Can get a new tone ring off Ebay for $8
bdboyle
Sep 16, 2019 05:58 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Amberlinder541
Sep 30, 2015 07:07 PM
Jaguar Forums Editor
Jaguar Press release
Sep 25, 2015 11:58 AM
