P1582 code and P0480 code reset
Old Sep 28, 2016 | 10:55 PM
carcster's Avatar
Default P1582 code and P0480 code reset
I am running 2 codes I can't clear. After searching it looks like code P1582 is a dealer only code, Flight recorder data.....LOL, this is not an aircraft. The second code is P0480 that seems to be a cooling fan relay. Some would suggest getting an entire new cooling fan assembly but I want to just try the sensor that would negate this code mounted to the fan. Anyone have current experience with these code? From what I understand it takes a PDU, WDS, or IDS to clear these check engine lights. I am more worried about the fan sensor than the flight recorder is stores, throttle monitor data is stored code P1582
Old Sep 29, 2016 | 02:21 AM
JagV8's Avatar
Ignore the P1582 as it's harmless. The other should self-clear if fault fixed or any OBD tool should clear it (your law says this, and Jaguar seem able to obey the law).
DavidC
Dec 29, 2024 04:14 PM
Muhammad Umer
Oct 3, 2016 09:44 PM
rjh
Sep 6, 2016 02:19 PM
rhscare
Sep 6, 2016 05:46 AM
Johnny_B
Sep 5, 2016 10:00 AM
