P1647 O2 sensorship problem
Old Jun 13, 2018 | 02:26 AM
Michael C Smith's Avatar
Originally Posted by dwclapp
Bosch 15627 is the correct O2 upstream sensor for Bank 1 & Bank 2. I don't know the Denso part #.
$55 is a great price. Suggestion: Buy 2 if both sensors in your car are factory originals. When one fails, the other is not far behind. Mine triggered error codes at ~100 kmiles for Bank 1 and at ~115 kmiles for Bank 2 on a 2002 2.5L X-Type Sport.
This is the Denso Upstream part number and the downstream part number is 234 - 4798
Old Jun 13, 2018 | 04:07 AM
Old Dec 30, 2022 | 02:28 PM
22bababababa's Avatar
Originally Posted by ltmax
P1647 is ECM HO2 Sensor control malfunction bank 2 upstream, if you changed the one closest to the firewall, unfortunately you changed the wrong one as the firewall side of the engine is bank 1.
Bank 2 is the front bank closest to the radiator. Recommend that you swap the old sensor you took out for the one at the top of the front catalytic converter and you should be back in business. No need to buy another sensor as I think that the used one should fit just fine.
Good luck and let us know how you get on.
i replaced the lamda sonda with black cable with new one , it does not clear error fault
Old Dec 30, 2022 | 08:45 PM
Dell Gailey's Avatar
Did you buy an OEM or a cheap internet part?
Old Jan 1, 2023 | 10:37 AM
JagV8's Avatar
Check the other items for that code such as fuses, relays, wiring.
But be SURE you bought a proper part.
RaceDiagnostics
Sep 7, 2025 11:01 AM
carl purchase
Oct 14, 2015 06:14 PM
Heliwilly
Jul 26, 2015 10:53 AM
kalacho2006
Mar 23, 2013 06:18 PM
zibby_uk
Nov 1, 2012 09:41 AM
