pecus error e
Old Nov 21, 2018 | 12:55 AM
p911's Avatar
Default pecus error e
jaguar x type 2004
this morning ive get pecus e error code and unable to start
Old Nov 21, 2018 | 02:23 AM
JagV8's Avatar
As you can see this is not the X-Type forum.
Also, use Search about pecus.
Old Nov 21, 2018 | 07:56 AM
I've moved your post to the appropriate X-Type model forum for better response. As JagV8 mentioned - you can use the search feature to locate info. As this is your first post, please take a moment to stop by the New Member section and post an intro. In return, you'll receive a warm welcome and useful tips to navigate the forum.
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Nov 21, 2018 | 12:36 PM
Dell Gailey's Avatar
Pecus stands for = "Programmable Electronics Controls Units System"
The suffix e means ECU
Most common causes are:
1. Failing or dead battery (low voltage)
2. Battery leads corrosion and not connecting properly (again low voltage)
3. Water intrusion into the ECU
4. ECU failure
Here is a link to a test (pin out) to check things =
https://www.justanswer.com/jaguar/7y...type-2-5l.html
Don B
General Tech Help
Nov 9, 2015 12:59 PM
gambino01
Apr 6, 2014 02:33 PM
BuckMR2
Jan 23, 2011 06:18 AM
nemesis1109
May 13, 2008 05:08 AM
