Please Help - Nav out, heater stuck on,
Old Mar 3, 2008 | 09:44 PM
ibjags's Avatar
Default RE: Please Help - Nav out, heater stuck on,
Good luck
I dont have part # for nav reader but it is in the trunk
you know the thing you put the DVD discinto
and if possible i"d try and plug and play a unit before purchasing one
i think the other guy just paid 700.00 for his?
lot of money to be out if its not the fault
not sure about Ebay return policies
Old Mar 29, 2010 | 10:12 PM
QuadManiac's Avatar
Originally Posted by ripsjag
DISREGARD, found other blog with exact problem
So, can you favor us with the solution, so we can keep it in our troubleshooting toolbox?
Old Jun 18, 2018 | 10:59 AM
Catrick's Avatar
Hello
I have a 2003 x type with 40,000 miles . The screen is locked and the car appears to be in the defrost mode . I can not change the blower speed . The dealer scanned the car and recorded the following codes ; u1900 , c1279 , p1582 , u1900ip . The dealer said the car has a communication problem . They checked the ecu for moisture and found it dry. The car has a lot of rust at the outer box sections ( rocker panels ) and at the base of the a pillars . I suspect an electrical connection may be rotted but I do not know where to start
Thank You. catricks
Old Jun 18, 2018 | 10:24 PM
Dell Gailey's Avatar
Try easiest fix first. Eject dvd(cd) in trunk reader and reinsert. This disk has all the control software for climate control on it.
Old Jun 23, 2018 | 03:35 PM
Catrick's Avatar
Dell Gailey Hello Sir
Thank You for your reply. I r+r the nav disc several times and ended up with messages ;communication fault please consult dealer ,engine off no ac available.l do get the menu display but I get no response to;recirculation, defrost , ac , auto , hot/ cold buttons , blower speeds . I do have response to audio . As I said earlier I feel it is stuck in defrost mode. Is this a default setting? The car also has a check Engine light with a D C T 1699 .
Thank You for your time and expertise!
Catricks.
Old Jun 23, 2018 | 04:03 PM
If you ejected the disk and the condition did not reboot, the disk has gone bad (VERY rare), the more likely cause is the dvd unit died. The programming for the screen and a/c-heat controls are on the disk. Audio has nothing to do with the disk software. Lots of people have fraked around in the hidden menu and "accidentally" pushed the s/w (software update) which gives you the 50-51 error and blank screen. The fix for that is the same = eject and reload the disk. I assume you have already checked for a blown fuse. Fuse box diagram is on first page in the "stickies" section to look for/find the correct fuse.
Old Jun 23, 2018 | 04:24 PM
Your DCT1699 converts to the correct OBD code id P1699 which is a canbus code for ECU and CCM communication fault. There could be a fault in the wiring or modules.
https://www.jaguarforums.com/forum/x...-codes-132633/
https://www.justanswer.com/jaguar/78...99-direct.html
https://www.jaguarforum.com/showthread.php?t=47549
https://www.jaguarforum.com/showthread.php?t=27575
Finbarr1975
Sep 5, 2025 08:38 PM
Paora
Feb 4, 2021 12:36 AM
Finbarr1975
Oct 4, 2015 05:32 PM
inactualis
Oct 2, 2015 11:13 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
