PO420
Old Oct 12, 2018 | 02:50 PM
  #41
Dell Gailey's Avatar
P2A01 O2 Circuit Range / Performance (Bank 1, Sensor 2)
Possible causes
Faulty Rear Heated Oxygen Sensor Bank 1
Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
Is this perhaps the one you just bought the "OEM" denso and replaced?
Old Oct 12, 2018 | 04:19 PM
  #42
iownme's Avatar
indeed it is
i'll check wiring when i get a chance tmrw. im thinking of selling everything and buying an F type.. lol
Old Oct 12, 2018 | 05:29 PM
  #43
iownme's Avatar
i had this as a pending code earlier after all monitors passed and before the check engine light.
Old Oct 21, 2018 | 11:53 AM
  #44
iownme's Avatar
so is this odd?
all monitors passed
no check engine light but the P2a01 is still logged as a code but not tripping the CEL?
so i imagine it "should" pass an inspection/mot ???
Old Oct 21, 2018 | 01:54 PM
  #45
I think that's all State specific. Here I had one pop up as I drove into the check station (had OBD going). Didn't set off the MIL & it passed. I even told JP (the owner) it has thrown the code as I entered his lot. He said no MIL and 1 here passes.
Old Oct 22, 2018 | 08:23 AM
  #46
iownme's Avatar
great!
hope i can keep that light off for a few days until i can get it inspected!.
new sensor arriving today...el cheapo this time!
i'll likely wait till after inspected before installing...unless CEL comes back on beforehand
Old Oct 24, 2018 | 06:05 PM
  #47
iownme's Avatar
Originally Posted by Brutal
you know you could have spent $25 on a 02 sensor extender and been done already. I have used these for years and never failed to fix.
ok brutal...i should have tried your way first.
where do i get an 02 extender?
Old Oct 24, 2018 | 07:06 PM
  #48
18 mm X 1.5?
https://www.ebay.com/itm/Straight-O2...-/173306063856
Old Oct 25, 2018 | 08:51 AM
  #49
Brutal's Avatar
WWW.BIGDADDIESGARAGE.COM
Old Oct 25, 2018 | 10:38 PM
  #50
iownme's Avatar
i tried their mini cat and im getting other codes but not the 420... is that what u had sucess with or did u use a plain extender such as dell posted (thanks dell ;@)
Old Nov 4, 2018 | 09:57 PM
  #51
iownme's Avatar
alas it dont look good!
today i thought id try just the new sensor without the mini cat.
the sensor would not go in the bung.
i went down with my little finger and found the bung was all bunged up with what i assume is a chunk of catalytic converter.
i was able to push it back and i could feel a lot of other chunks of what i assume was more catalytic converter inside.
i smashed up some big chunks into smaller chunks with a screwdriver but im sure the only answer is another cat.
dr dome has said he can do the work and is a drivable distance so if mashing the inards of my cat doesnt somehow miraculously work....then engine removal is rhe only fix.....well ya cant say i havnt tried everything else... lol
Old Nov 5, 2018 | 04:32 PM
  #52
Dang!
Old Nov 5, 2018 | 06:56 PM
  #53
xjagRI's Avatar
Sorry to hear that. I bought a cheap endoscope so I could take a look inside. Fortunately, the cat medium was in good shape for me. I’ve read on the forum that you are able to get the broken cat medium out, a regular cat couldbe added to the exhaust system at a more convenient place. May be worth looking in to.
Oliver9218
Oct 24, 2018 05:15 PM
dino88
Mar 23, 2009 04:26 PM
