Propshaft Dilema
Old Jan 19, 2009 | 02:07 AM
ferret's Avatar
Default Propshaft Dilema
Well here we go again, took my X to a well known and respected garage again on Saturday to try and diagnose the whine comming from somewhere under the car at between 29 & 31 mph (temperature above freezing), the mechanic took a drive with me and said yep i can hear it we took it back to the garage on the ramps and he gave the underneath a real good looking over checking everywhere for any leaks etc - result all looking good with no leaks anywhere, he decided that it could be the prop bearing but said it looked perfectly good checking for movement etc with good signs of grease. His decision was that a lot of these Jags have this problem / fault / and its not a safety issue but more of a dammed anoyance..Recomendation..qoute "if we replace it - it may not cure itas sometimes it dontso you have spent money fo nothing / put up with it / a new prop at £400 quid + / or a replacement bearing which could meen cutting the prop in half to replace the bearing (depending on the one fitted) + re-welding + re-balancing + re fitting which can be just as expensive....... what would you guys do apart from wearing earmuffs while driving. I think jag should do a re-call on this problem but they wont if its not a safety issue. car has only just covered 14,000 mls.
Old Jan 19, 2009 | 09:53 AM
mohrd's Avatar
Default RE: Propshaft Dilema
Refer to the posts about greasing the Prop Shaft center bearing. If not wanting to try that, get a new Prop Shaft unless you can put up with the sound. I couldn't. Cutting, welding rebalancing, etc would probably end up costing more than replacing and you'd have a weaker component. Your dealer will have one on the shelf waiting for you because as you said, it's a known problem althoughnot a safety recall problem. The new Prop Shaft is quiet...
Old Jan 19, 2009 | 10:14 AM
Dennis's Avatar
ud
Check out this thread.. https://www.jaguarforums.com/m_85101/tm.htm
Old Jan 19, 2009 | 12:14 PM
McJaguar's Avatar
ORIGINAL: ferret
I'd agree with ALL of that (except maybe the part about "may not cure it", 'cuz I can;t imagine any scenario where replacing it won't cure it)
Old Jan 19, 2009 | 12:57 PM
ferret's Avatar
Thanks for the links Dennis , but been there / done that /got needles etc / been on my back squirting grease in it...the result was ..still have the damn whine but many thanks again for that info
ORIGINAL: Dennis
Old Jan 19, 2009 | 01:09 PM
Real_Tech's Avatar
It's not really the bearing making the noise, that's why greasing didn't stop it. It's actually the rubber portion surrounding the bearing allowing the harmonic finger on a wine glass sound so typical of this problem. You can try absolutely soaking the rubber portion with spray silicone wet lube but I can't guarantee results. Cold weather just makes the problem worse, I've heard the noise during 80 degree weather as well.
Old Jan 19, 2009 | 02:34 PM
dgrelecki's Avatar
Get used to it, it's just your cat purring.........lol
Old Jan 19, 2009 | 04:33 PM
ferret's Avatar
well it must be a realy hungry large cat lol.
ORIGINAL: dgrelecki
Old Jan 20, 2009 | 12:32 PM
DZtt's Avatar
ORIGINAL: Real_Tech
I couldn't find words to explain the sound i was hearing this winter but the finger on a wine glass is exactly what it sounds like. Is this just a sound that you can ignore and wait till spring or is there something that needs to be checked out/fixed? I only hear it on really cold days when the car hasn't warmed up completely and under 25mph.
Old Jan 20, 2009 | 01:19 PM
billinohio's Avatar
joking here but I "fixed it!", when I get in and it's freezing outside, I let car warm up anddrive and turn radio on, still hear it? turn radio up! rinse, repeat! Bill
Old Jan 20, 2009 | 05:47 PM
christo's Avatar
Mine was quiet today going and coming from work - it was in the teens this morning and mid twentys on the way home. I did let the car warm up in both instances.
Old Jan 20, 2009 | 07:04 PM
mohrd's Avatar
Bill, eventually the volume increase will blow the speakers...but good temporary solution.
Old Jan 20, 2009 | 08:09 PM
Real_Tech's Avatar
The sound is just an irritating noise. I have yet to see any sort of mechanical failure of an X-Type drive shaft. Some are noisier than others, I drove one yesterday that screamed so loudly I swear you could hear me coming from a mile away and it did it all the time. The customer declined the repair. I couldn't have lived with that noise for more than a mile but usually they make noise first thing in the morning or just on decell coming up to a traffic signal.
Old Jan 21, 2009 | 07:23 PM
elardizabal's Avatar
ive had the same problem so i took mine to the mechanic based on the conversations on these forums, they ended up replacing a "bearing" (they didnt tell me which one) and to be honest THE WHINING STOPPED! but in return... ive got reverberating sound of which i believe is coming from the prop shaft... So Bill is right I DO TURN UP THE MUSIC!
b1mcp
Mar 18, 2021 11:06 PM
millertic
Sep 12, 2015 06:47 PM
Sshenton1975
Aug 30, 2015 09:29 AM
iownme
Feb 23, 2012 09:38 PM
