Question??? Disconnecting the battery
Old Dec 21, 2010 | 08:57 PM
vai1953's Avatar
Default Question??? Disconnecting the battery
I just installed new plugs, IMT o-rings, and intake manifold gasket. Everything is working ok, except my outside temp runs all the way up to 105 degrees. It was never right to begin with,always about 9 degrees off. I was just wondering if I disconnected the battery to reset the system, would it have any effect on the outside temp setting. I like everything to work even if it's off a little, but this just goes to 105 and stays there. I have heat and I guess the A/C, will have to wait until summer. Anyone have any ideas. I checked all the area's I was working in, in case I jared a wire or connector, and I went over everything, but I couldn't find anything loose. Thanks for your help everyone.
Old Dec 22, 2010 | 06:42 AM
The Chris X's Avatar
Probably a sensor problem. The sensor is clipped right in front of the radiator, you can see it in the front bumper opening by the splitter.
Old Dec 22, 2010 | 08:16 AM
vai1953's Avatar
Default Sensor wire travel direction and connection
I've checked the sensor and followed the wires up until it goes into the headlight area. Without moving the battery, I can't see where the wire comes out at. As I was working (IMT o-rings, rear plugs, intake manifold), I had layed some tools down on that side, but I'm not sure what connection the sensor follows or where the wire travels threw the fire wall. Yes the sensor most likely is bad, since it always read about 9 degrees warmer than it really was out side. But this didn't happen til yesterday when I did this work, so I know I hit something or moved something to make the outside temp gauge go from 60 to 105 after the car hits running temp, in the matter of a minute.
Forcedair1
Sep 8, 2025 01:57 PM
philwarner
Oct 4, 2024 01:37 PM
Dagny
Jun 11, 2024 01:06 PM
SeanU
Sep 13, 2015 02:45 PM
DEklof
Sep 8, 2015 05:28 PM
