Quick Question About Trans Fluid Level Check.
Old Jun 23, 2018 | 11:55 PM
AndrewG's Avatar
Default Quick Question About Trans Fluid Level Check.
So from what I understand you need to get the tranny fluid up to about 95 degrees f. Then get the level check plug off and let it drain till it doesn't anymore, or add fluid till it drains out of the level check plug.
My question is will having the car only raised in the front affect the level plug reading? I have these ramps I drive the car onto and was planning on using those for this of course. However since the car would then be on a grade I'm concerned I'll get an inaccurate reading.
Thanks,
Andrew
Old Jun 23, 2018 | 11:59 PM
Dell Gailey's Avatar
Has to be level. I'm sure you've read which is level plug and which plug disengages the reverse band.
Old Jun 24, 2018 | 02:13 PM
AndrewG's Avatar
I've seen pictures on these forums showing where it is, it's on a wall just below a blue and red thing with a cord coming out of it.
Old Jun 24, 2018 | 02:58 PM
Read this for assurance =
https://www.jaguarforums.com/forum/x...ms-oil-199408/
Etip
Jan 4, 2022 11:13 AM
FactoryJaguarTech
Nov 28, 2019 02:53 AM
crtfour
Apr 12, 2018 03:04 PM
Redeye
Oct 15, 2014 03:42 PM
