rear diff and TC oil - repost of info
Old Oct 6, 2008 | 11:03 AM
racerx82's Avatar
Default RE: rear diff and TC oil - repost of info
Good info Bo, thanks!
Old Oct 7, 2008 | 08:58 AM
RudyF6's Avatar
In the Ford world that spec# is for 75w140 synthetic axle lube. XY75W140QL is the Ford p/n. I sell it for MSRP of $21.04/qt.
Old Oct 7, 2008 | 04:32 PM
Wild Bill's Avatar
Actually I would be a little cautious with the oil you use.
STA-LUBE SYN-GO, FULL SYNTHETIC GEAR OIL (SAE 75W-140)(SL2496)
meets Jag/Ford spec M2C192A for a synthetic SAE 75W140 lubricant.
You can get it at NAPA for $44.79 for a 2 quart bottle.
Doing a chemistry experiment in your transfer case is a very expensive risk in my opinion. Since the 2 qt bottle will do the transfer case better than three times, it's only as expensive as the $15.00 stuff that might work. Why use stuff that doesn't specifically meet the spec to save no money?
Just my $.02 worth.
Old Oct 7, 2008 | 04:48 PM
racerx82's Avatar
Diff oil is very important, or for that matter the correct oil for the job is always important. Using the wrong kid/viscosity will fry whatever it wasn't intended for! Case in point, years ago, I was working on a 69 GTO, we just put in 4.11 posi multi clutch and i left for the day with instruction to the owner to add the posi lubricant, which was only a little 5 or 12 oz bottle of fluid. The case took 4 qts of 90wt (plus the little bottle of posi oil).
Anyway, the next day the car was all done and he took it away...happy as a pig in some kids house crapping under the bed......4 months later the posi was destroyed...clutches burnt to hell......
We figured it was defective....so in goes another one, brand new. I leave again, since he doesn't need me to add oil.......
Another 4 months later and you guessed it...fried his second rear.....we were both like WTF....
So we oder a third one.....install it and as i go looking for some rags in the bottom of his tool box, i find two bottles of posi lubricant! I was like, dude, why didn't you add this to the first case??? he was like, it's just oil...doesn't matter.....Yikes!
Anyway, long story short, we added the little bottle of oil to the posi and the freaking thing never came back for a 4th! lol
OIL IS IMPORTANT
Old Oct 7, 2008 | 06:23 PM
JagXV6's Avatar
A GM 12 bolt takes more like 5.25 PINTS, not quarts.
The limited slip additive is 4 ounces. (I think it is whale oil???)
That makes up the 0.25 part of the case capacity.
That rearend should have been chattering and grabbing
all over the place long B4 it burned up the clutches. Did
ya find any stupid pills in his tool box too?
Red Line gear oil isa full synthetic gear oil and as Bo
pointed out, will be fine in the rear end.
Old Oct 7, 2008 | 08:46 PM
racerx82's Avatar
lol...na, we were young back then and it was fun (from what i remember) pints, qts, what's the diff?? (get it diff...as in differentail....) hahahahaha....all i really remember is that thing smokin the tires all to hell!!
Old Oct 7, 2008 | 09:18 PM
Wild Bill's Avatar
To the best of my knowledge, Red Line does not claim that their synthetic gear lube meets the Jag/Ford spec. I believe that if you write to them they will extol its virtues, but they will not say it meets the spec for the transfer case.
As I said, since there is no reason not to use the lube specified, I'd stick to what is called for. Of course, you are free to do to your car what you want.
Old Oct 8, 2008 | 08:58 AM
racerx82's Avatar
Are we talking about Red line beer?
Old Oct 8, 2008 | 09:07 AM
RudyF6's Avatar
NOOOOO nonono!!! Don't drink red beer!!!
[:'(][sm=smiley11.gif]
Old Oct 8, 2008 | 09:33 AM
racerx82's Avatar
Ah..now that's the best tip ever! thanks!
Old Oct 8, 2008 | 09:45 AM
scubayachts's Avatar
Does anybody know if amsoil makes a tcase and diff oil that meets jag specs?
Old Feb 8, 2019 | 09:12 AM
car5car's Avatar
Bump
kelliott
May 31, 2022 05:26 PM
jdzubas
Oct 4, 2015 09:14 AM
AL NZ
Sep 4, 2015 08:39 PM
pnwrs2000
Sep 3, 2015 11:55 AM
OkieTim
Sep 2, 2015 12:48 PM
