Rear hub carrier bush’s
Old Nov 27, 2022 | 06:47 AM
Norcat's Avatar
Default Rear hub carrier bush’s
The front bush’s on the rear hub carrier arms are looking a bit tired. Has anyone managed to replace them with out removing the whole hub carrier from the car. I was thinking if I took the bolt out and levered the arm down and put a block between it and the bottom of the car to hold it out of its bracket, I think there will be enough flex in the other linkages to give me a few inches. Then remove the bush and press a new one in with a tool made up from large sockets and threaded rod to pull the bush into the arm.
What do the experts think?
Old Nov 28, 2022 | 06:01 AM
I've moved your question from UK & Eire Region to X-Type forum. This is the place to post technical questions about your model.
masingleton
Jan 24, 2021 04:02 PM
laguillotine
Mar 7, 2020 09:45 AM
OptimusDiesel
Feb 4, 2018 05:23 PM
elvinjones
Feb 27, 2015 10:26 AM
PaleRider
Jan 12, 2015 12:10 PM
