Replacing Fuel pump and filter
Old 05-10-2016, 12:17 PM
Mr rx-7 tt's Avatar
Default Replacing Fuel pump and filter
I need to replace the fuel pump and filter in the Jag. Has anybody else done the job? Any tips or special tools or parts other than the fuel pump and filter? Oh where is the filter?
The dealer says this is a common problem for the X-type.
Thanks in advance.
Old 05-10-2016, 12:52 PM
Mr rx-7 tt's Avatar
Old 05-10-2016, 12:53 PM
Lemons Racer's Avatar
I have never replaced the fuel pump, but under the rear seat is an access port. I can take a picture if you want before you remove anything. The filter is easy to get to. Go under the passenger side of the car. You will see the fuel rails running under the passenger seat area. Follow them back and it is sandwiched up between the tank and where the back seats start to go up.
Mr rx-7 tt (05-25-2016)
Old 05-10-2016, 01:03 PM
jmott's Avatar
Here is a step by step bulletin I used when I did mine several months back
Jason
Old 05-10-2016, 01:10 PM
Mr rx-7 tt's Avatar
The dealer just called, they want $2025.00 to replace the fuel filter and pump.
Old 05-10-2016, 01:11 PM
Mr rx-7 tt's Avatar
Can you replace the fuel filter without dropping the tank? If you have a picture that would be great!
Old 05-10-2016, 01:16 PM
jmott's Avatar
Yes. If you jack the rear of the car up you will see the fuel filter on tha passenger side of the car in front of the tank.
Old 05-10-2016, 01:19 PM
Fuel filter is an easy fix. I can get real pictures if you want later this week, but the bulletin that jmott posted above is great. Under removal steps 5-7 it shows what it looks like under the rear seat cushion. The fuel filter is easily accessed from under the car and is shown under step 22. It says it is a quick release coupling so you will need to get the tool to release it. They are less than $5 at any auto parts store. They do come in different sizes and I'm not sure what size this is so you'll have to check. If you go under your passenger side and look up between the rear seat and the tank you'll see it.
Old 05-10-2016, 01:29 PM
Mr rx-7 tt's Avatar
Sorry I meant the fuel pump, can you replace the fuel pump through the access hole in the rear?
Old 05-10-2016, 02:12 PM
Sorry, that I do not know. It would appear that you can, but I have not pulled it out or really even looked. Just took out the seats and noticed the port to it with the electrical connections there. It has been a little while and I do not remember the process of removing the base of the back seat, but I do not recall it being too difficult.
Old 05-11-2016, 09:22 AM
foxbottom's Avatar
My understanding is that there is no access port under the rear seat, but that you have to cut an access hole -or else drop the tank. There was a post on here with pictures of how to do that.
Old 05-11-2016, 11:35 AM
foxbottom's Avatar
https://www.jaguarforums.com/forum/x...-130721/page2/
Here is the thread I was talking about.
Old 05-11-2016, 02:20 PM
Mr rx-7 tt's Avatar
Yeah, I've replaced two fuel pumps in my Saab's. Some people cut out the hole a bit larger so they don't have to drop the tank. The car, Jag, is pristine, so I will either drop the tank myself or take it to an Indy if needed.
Old 05-13-2016, 01:48 PM
Here's what is under the seat. It does not look like fuel pump access.
Old 05-13-2016, 02:14 PM
Alfadude's Avatar
No fuel pump access, but a lot of beer bottle caps.
Old 05-13-2016, 04:07 PM
LOL, we got told to clean it out. I took some out of the fuel area for the picture
Old 05-13-2016, 11:13 PM
Diavolo's Avatar
about halfway down on my re-build thread i changed the fuel filter, pic here:
https://www.jaguarforums.com/forum/x...-121873/page2/
Originally Posted by Diavolo
Replaced the fuel filter today, and pumped out about a 1/4 tank of old gas.
Took 10 minutes.
The only tools required were an 8mm wrench and a beer.
Also helps to have a pan to catch fuel in.
The connectors on either end of the fuel filter are quite clever.
Its like unclipping a wiring harness. No hose clamps needed.
Today I ended up spending hours under my other car sorting out a sloppy feeling shifter that was caused by a nut that came off.
Didn't give me much time to work on the Jaguar, but at least I am able to check one more thing off the Jaguar's to-do list
Greencar89
04-18-2016 07:26 PM
ianf3
04-17-2016 12:26 PM
bazanaius
04-16-2016 05:46 PM
tat2dkjn
04-15-2016 02:29 PM
aholbro1
04-13-2016 01:53 PM
Quick Reply: Replacing Fuel pump and filter
