Replacing Windshield Reveal Moldings | 03 xtype
Old Feb 12, 2018 | 10:09 PM
AndrewG's Avatar
Default Replacing Windshield Reveal Moldings | 03 xtype
So the 2 vertical weatherstripping pieces on my jaguar xtype are pretty well rotted at this point.
Invested in a set of the reveal moldings, and they seem to be part of the plastic trim on ether end of the windshield too. So inspecting the back of the new pieces it kinda seems like it slides in and clips into somewhere.
Sadly I haven't found any videos on tutorials online to assist me here. Even though I could probably go out and figure it out a long the way, the location of these pieces is what I would call sensitive.
With that in mind hopefully you guys can give me some advice on how to tackle this job properly.
Thanks in advance!
Old Feb 13, 2018 | 08:15 AM
avern1's Avatar
The trim is held on by plastic clips mounted to the windscreen gasket. You pry off the trim starting at the base on the glass side and working upward. See attached blowup.
Attached Thumbnails Replacing Windshield Reveal Moldings | 03 xtype-x-type-windshield.jpg
Old Feb 13, 2018 | 10:36 AM
AndrewG's Avatar
Very helpful, thanks!
Old Apr 12, 2019 | 05:14 PM
Nicki Avera King's Avatar
How many clips are on each side and do they require a special tool to remove the molding from the clips?
Old Apr 12, 2019 | 06:36 PM
avern1's Avatar
It has been awhile and I don't remember the exact number but there was a bunch.
Tool wise I use a trim removal kit it has different pry bars made from nylon and plastic so as not to scratch the paint work.
Old Apr 12, 2019 | 08:36 PM
Dell Gailey's Avatar
Like this =
Old Apr 15, 2019 | 01:34 PM
MeatBag's Avatar
I replaced the vertical windshield trim yesterday.
I did not have to use any tools.
Standing at the side of the car, pull directly towards yourself - working your way down the length of it to remove the strip.
The back of the new trim pieces has a tongue running the length of the strip. The tongue slips into the metal channel.
once positioned properly, I pounded it home using open palms and a fist.
Old Apr 17, 2019 | 12:56 PM
MeatBag's Avatar
Photo showing the molding removed and laying on the windshield.
You can see the metal channel on the left that the tongue on the back of the molding fits into. Note that there is a notch at the halfway point that you have to line up.
Old Apr 29, 2019 | 06:48 PM
RobinGa's Avatar
Do you mind sharing the part numbers for the trim you installed? Won’t be long for the rest of us I’m sure
Old May 10, 2019 | 10:47 AM
MeatBag's Avatar
there are two different part numbers one for left, one for right. At SNG Barratt they call it a "Finisher-win" and the passenger side part is C2S36549 and drivers side is C2S36550.
A bit pricey at $58 each for a 30" strip of rubber and plastic, but you bought the Jaguar instead of the Toyota, so no crying allowed.
Old May 10, 2019 | 04:19 PM
Alfadude's Avatar
So what would the cost of the Toyota part be? If they even have a strip like that, I would guess even if it would be cheaper, it wouldn't be that much.
Old May 10, 2019 | 05:40 PM
^^ lol, Alpha = yup, $49.99 average
Old May 12, 2019 | 07:27 AM
Alfadude's Avatar
Often OEM replacement parts, especially specialty trim type pieces, aren't cheap no matter what the car
Tommy Ferrugia
Oct 5, 2016 07:43 AM
Danomar200
Jan 30, 2015 09:08 AM
oldpunk
Apr 28, 2013 08:28 AM
portman5
XJ40 ( XJ81 )
Nov 28, 2012 09:09 AM
dmarti02
Dec 7, 2008 12:30 PM
