rough cold start
Old Jan 19, 2016 | 11:09 AM
micmee1's Avatar
Default rough cold start
My 04 xtype is starting very rough. Once it's starting to warm up, it seems to run fine, and starting again after errands, it starts, and runs just fine. Hubby is out of town right now, and if I can get pointed in the right direction, I would like to solve this.
Thanks for all your help.
M
Old Jan 19, 2016 | 03:49 PM
dwclapp's Avatar
Likely a vacuum leak. This thread discussed the top 3: https://www.jaguarforums.com/forum/x...1/#post1309725
The leak you have is most likely #3 (IMTT O-rings), or #1 (PVC breather hose) because they're made or rubber which stiffens in the cold, so it doesn't seal as well and more air leaks by.
Both are relative common and easy to fix. Do you have a trustworthy independent mechanic who works on Fords? Show him this post and the attached links, and he should be able to quickly find and fix the leak for you.
Let us know if you, the hubby or mechanic has any questions, and we'll help you from there.
Old Jan 20, 2016 | 03:56 PM
micmee1's Avatar
thank you for your help...much appreciated
m
Old Feb 26, 2016 | 07:49 PM
micmee1's Avatar
thank you again, i watched a couple of youtube videos on how to change the o-rings. I ordered them, and replaced them myself. Felt pretty darn good. Again, many thanks!
Old Feb 28, 2016 | 05:13 PM
Alfadude's Avatar
So, did that solve the issue and is the car running well again?
Old Feb 29, 2016 | 08:49 AM
DPK's Avatar
DPK
A woman of my dreams
Old Mar 1, 2016 | 11:09 PM
dwclapp's Avatar
Congrats! Feels good and builds confidence when you figure it out and fix it yourself.
caldercay
Sep 17, 2022 07:59 PM
nelsonht
Feb 15, 2016 06:15 AM
2001JaguarXJ8L
Feb 1, 2016 07:10 AM
peterg19
Jan 21, 2016 06:56 AM
Rajamogan
Jan 19, 2016 11:00 AM
