sound (bad roller bearing?) from behind the dash
Old Feb 24, 2019 | 04:18 AM
kingnero's Avatar
Default sound (bad roller bearing?) from behind the dash
My 2007 X-Type (which I have very recently) makes a slight/faint noise, coming from behind the dash somewhere between the steering wheel and the center console.
Sounds like a fan gone bad. But even when I turn off everything on the touchscreen, the sound keeps coming. Any ideas? Thx!
Old Feb 24, 2019 | 07:47 AM
ABR's Avatar
ABR
HI Kingnero.
It is a small fan, something to do with the A/C I believe, in the small air intake on the lower part of the dash. It continues to run for up to 20 minutes after the ignition has been turned off.
If you pull the front of the intake off, you can give the fan a small blast of compressed air that will blow any accumulated dust and dirt out.
This usually cures the "noise" problem.
Hope this helps.
Alan in sunny Malta (strong winds to-day....not so sunny.)
Old Feb 24, 2019 | 03:13 PM
Dell Gailey's Avatar
Old Feb 24, 2019 | 11:35 PM
kingnero's Avatar
Thx for the links, had used the search but apparently not very well...
Seems like an easy fix.
Old Mar 3, 2019 | 07:44 AM
kingnero's Avatar
To apologize, here's a pic...
annoying air sampling motor behind the dash
Sylbon
Jul 26, 2018 10:59 AM
iownme
Jun 27, 2016 04:49 AM
afterburner1
Feb 12, 2015 09:41 PM
shula
Feb 11, 2014 11:00 PM
adam699
Feb 22, 2012 04:20 PM
