standard head unit with new subwoofer
Old May 1, 2009 | 03:16 PM
silverjag04's Avatar
Default standard head unit with new subwoofer
hey i wanted to know if the head unit that comes standard in the car has outputs for a sub. the name of the output escapes me, but you use rca cables or speaker wire to connect the unit to the amp.
i eventually want to install a new head but for now i want to install a set of subs i have laying around.
thanks for any help.
oh i also read there are door clips that have to be replaced if you take the door off to change the speakers. what are these clips called so i can buy them before i take the door panels off.
Old May 2, 2009 | 01:54 AM
faze2's Avatar
No, it does not have outputs for subs. You need to wire in a fm modulator. The door clips, I don't think, have any specific name. Just go to the dealership and ask for door panel clips, they are probably a dollar a piece. But you should be able to remove the panel without breaking the clips, just be gentle.
Old May 2, 2009 | 06:42 AM
The Chris X's Avatar
Faze is correct, no RCA output or dedicated sub line.
I would go with speaker line input/output to a sub/amp combo rather than some type of modulator.
Old May 2, 2009 | 01:06 PM
faze2's Avatar
I used the fm modulator on my 02 X and my subs work great. Plus it isn't that expensive. Go to the install bay at your best buy and ask for one.
Old May 2, 2009 | 05:30 PM
alright so if i am careful ill be able to keep the door clips intact, where exactly are the clips? also has anyone changed there head unit and used a metra 99-9500 kit or another kit? is this kit any good?
thanks for the help so far
Old May 2, 2009 | 05:38 PM
also how do i remove the side sills to run wires underneath, i pried it up a bit and saw clips and tried to unclip them but still couldn't get it to come off?
Old May 3, 2009 | 05:36 PM
faze2's Avatar
The door panel clips should be located near the edge of the panel, just pry it out with your fingers a little bit and feel for them. On most cars there are three or four on each side of the panel.
For the inside plastic sills, just pry up and unsnap, it shouldn't be too difficult. The one for the rear door was more difficult, I couldn't get the entire sill up so I just shimmied the cables through the open part. And to get the power cable to the battery, there should be a thick rubber grommet that you can cut a little hole into and the aggressively squeeze the power cable through.
Old May 3, 2009 | 07:50 PM
christo's Avatar
There's a great write up in the FAQ's for door panel removal. I currently replaced all door speakers, added a sub and 2 amps - all running off 1 low level converter. Was a pain to get 5 channels out of 2 but it sounds great. I plan on replacing the head unit this year with something fierce.
Old May 4, 2009 | 08:05 PM
thanks i totally forgot about that. yeah i want to put in a kenwood exceleon nav unit but i dont know if it will fit in the above kit but ill try
Dz1rfj
Jul 17, 2018 10:29 AM
42Ajd
Dec 30, 2015 09:45 AM
42Ajd
Sep 21, 2015 07:37 PM
Dz1rfj
Sep 16, 2015 03:44 PM
1LowCat
Sep 14, 2015 07:51 PM
