Tps sensor
Old Feb 20, 2018 | 07:31 PM
Mrtwill4588's Avatar
Default Tps sensor
Hi, i have a 2002 jaguar x type 2.5 and while changing my plugs and coils i must of bump and hit the throttle position sensor connector because the wires came out of the connector and the connector was smashed. When i started the car the check engine like came on and the red explanation mark was on. The codes that my reader gave me was a p01222 and p0121. It said something about low voltage to throttle position sensor. The car is idling real high. I ordered another denso tsp that had a connector with it. My question is the wires that came out of mine are black/yellow - yellow - purple - and orange. The one i ordered has black/yellow - yellow - red - orange. So would i just crimp my purple to the the red?
thank you.
Old Feb 20, 2018 | 07:47 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...wiring-120889/
Old Feb 24, 2018 | 09:58 AM
Thank you. So which wire is the ground, power, and signal wire?
Old Feb 24, 2018 | 07:12 PM
Bottom right side of the pic =
2014-04-28_0945
Old Feb 25, 2018 | 05:08 PM
2014-04-28_0945
thank you guys. I hooked up the new connector and plugged it in to my tps and now the check engine light is gone, the limp mode light is gone, and my rpms are back to normal.
hoodun
Apr 26, 2012 10:15 PM
reddog120247
General Tech Help
Apr 6, 2012 07:35 PM
hdsg
Sep 25, 2011 08:29 PM
