Trans and transfer case fluid check?
Old Jan 30, 2018 | 05:51 PM
footbrake's Avatar
Default Trans and transfer case fluid check?
I have a 2004 X-type 3.0. I have already replaced the TC & Trans at 100,00 miles. Seems like when the trans goes it also takes out the TC, a dealer Jaguar mechanic told me. I would like to check fluids so I won't be going through this costly expense again. How do I check these fluids? Thanks for any input.
Old Jan 31, 2018 | 10:07 AM
avern1's Avatar
Attached are the procedures for the transmission and transfer case. You should get some kind of indication on the ground if you are having leaks and loss of fluid. The biggest cause of failure is the hard acceleration from a standing start. The transmission and transfer case just can't handle the stress. It is unusual for the transfer case to fail as a result of transmission failure. It's usually the transfer case fails first.
Attached Thumbnails Trans and transfer case fluid check?-trans-fluid-check.jpg   Trans and transfer case fluid check?-transfer-case-fiill.jpg
Old Jan 31, 2018 | 01:41 PM
footbrake's Avatar
Thank you, maybe it was the Transfer case first. It all happened the same day after my wife said there was a lot of noise going on .
mrplow58
Aug 29, 2015 10:44 PM
Maxmaxemus
Apr 22, 2013 09:18 PM
yeeran
Dec 5, 2011 03:11 AM
jag2020
Nov 7, 2010 03:53 PM
mr.xtype
May 11, 2008 09:20 PM
