Transfer Case Alignment Shaft Nut Torque
Old Sep 14, 2024 | 10:12 PM
95naSTA's Avatar
Default Transfer Case Alignment Shaft Nut Torque
I've seen a few threads with folks rebuilding their TCs but can't find a mention of what the torque should be for the large alignment shaft nut on the side of the case. Does anyone have a torque spec for this? Looking for a real number vs. torqueing it down to the same position.
I'm not asking about the output flange nut. I know that requires a rotational torque of 1.7Nm without the output part of the case installed/meshed with the rest of the TC.
Old Sep 14, 2024 | 10:49 PM
farm-jag's Avatar
Is it a but you are referring to or a bolt? Only thing I see on the side is the engine roll restrictor but it's a bolt. That is 80 Nm.
Old Sep 14, 2024 | 11:03 PM
95naSTA's Avatar
This is the nut I'm referring to:
Old Sep 15, 2024 | 09:38 PM
Dell Gailey's Avatar
https://www.jaguarforums.com/forum/x...s-60135/page2/
Old Sep 15, 2024 | 09:46 PM
95naSTA's Avatar
That would be one of the threads I mentioned.
Old Sep 15, 2024 | 10:34 PM
farm-jag's Avatar
I honestly don't see that on the shop manual either. Is it the same bolt (size and material) as the companion flange retaining nut? I've not done this job so I don't know. If it is, most of the time toque is based on pitch,baize, material etc. of the actual hardware itself and can be derived from that.
Old Sep 16, 2024 | 10:02 AM
95naSTA's Avatar
I didn't see it in the FSM either.. I'll have to compare it to the output flange nut. I know there's a TSB for the output shaft seal that specifies 160Nm on the nut if that's the case. I'm also familiar with those default torque settings, I just want to be careful I'm at the correct setting since it'll pre-load the conical bearings on that shaft to some degree.
Peter_of_Australia
Oct 19, 2024 10:03 AM
MrAndersonGCC
Jan 31, 2022 12:24 AM
JBRoberts
Jul 10, 2021 10:21 AM
Rogelio Serrano
Dec 29, 2016 10:38 PM
TonyX
Nov 13, 2016 07:43 AM
