Trunk Latch
Old Sep 22, 2011 | 07:55 PM
Carl-Eric's Avatar
Default Trunk Latch
Hello All,
My trunk (boot) latch has been acting weird. It does not latch on occasion.
My fix is to hit the open button on the trunk lid when it is open, then it will close.
Does not matter if I use the key fob or manually open the trunk, it randomly occurs.
Is this a British electrical issue? - Note one battery terminal has white powder on it. I disconnected, cleaned, and reattached- perhaps battery issue? Kitty has Jaguar battery.
2002, x-type, 3.0, 143,000 km, Automatic, Canadian.
Thanks for any reply.
Old Sep 23, 2011 | 09:31 PM
ez53436's Avatar
I have the exact same problem as you. I usually avoid using my trunk now because I'm afraid that opening and closing it is going to make it worse and that eventually it won't close!
Old Sep 23, 2011 | 10:25 PM
Carl-Eric's Avatar
I find that hitting the trunk button before closing always works -- so far, just wondering if it is something else.
Thanks for yur reply
Old Sep 24, 2011 | 09:47 AM
RudyF6's Avatar
Since you say actuating the latch before closing it usually works, it sounds like the latch just needs to be cleaned and lubed - may not be fully releasing the latch when you open it. Start with a penetrant, open and close repeatedly a dozen times or so, then squirt some lube (I like WD-40) in the latch, especially between the moving parts.
Old Sep 24, 2011 | 09:04 PM
motorcarman's Avatar
Here are the TSBs again
bob gauff
Old Sep 24, 2011 | 09:10 PM
Carl-Eric's Avatar
Well I sprayed the trunk latch with WD-40.
Will let you know with the outcome. Looks positive so far.
bdboyle
Nov 6, 2015 02:07 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
magmedia
Oct 8, 2015 03:28 PM
millertic
Sep 30, 2015 08:11 PM
