Two other leaks (pics)
Old May 8, 2013 | 01:43 PM
RedXJ40's Avatar
Default Two other leaks (pics)
I found two other "wet" places.
One of them is under the hood, it looks like it is sweating a little oil there.
Is this bad, where is it coming from, head gasket????
On this other spot, i found a drop of coolant, under the car.
Where is that coming from you guess?
Attached Thumbnails Two other leaks (pics)-8721418594_c60078acdb_b.jpg   Two other leaks (pics)-8721355144_b61ac762ea_b.jpg   Two other leaks (pics)-8720232293_f3497023e9_b.jpg
Old May 8, 2013 | 10:00 PM
AlfaVeloce's Avatar
Does your car have the green colored antifreeze/coolant in it? Or the red/orange/reddish orange type? Cause the pictures #1 and #2 look like green coolant. In the pics, anyway.
Look in the "overflow" tank on the left fender. What color is in that?
Old May 9, 2013 | 06:10 AM
Jagman68's Avatar
Smile
In your first picture I would say its one of the gaskets leaking its not a head gasket more like the small round sealing gasket for the inlet manifold.
If the second picture leak colour is bright green it could be A/C fluid?
Best of luck
Danny
Old May 10, 2013 | 09:55 AM
amcastro1's Avatar
I had the same problem with cooling liquid dripping underneath the car.
It was the liquid reservoir cap that was not fully tightened.
Old May 10, 2013 | 11:44 AM
Justicejamesb's Avatar
Easy to fix. Get a can of "Steel-Seal" and follow the directions on it. Should take care of the issue.
Old May 10, 2013 | 03:00 PM
Jeeves12's Avatar
Djurre1980,
Looks like you have a coolant (green) leak, as well. I had coolant showing up at the same location. If I recall there is a gasket at location #1 and an o-ring at location #2.
Location #3 is the PCV. I would replace this and the upper and lower o-rings for the intake mainfold. You're getting oil blowing past the PCV, then leaking out through the manifold o-ring gaskets. Eventually, you'll have a misfire and then car will go into limp mode - "cruise not available" message will show up.
Keep us posted on what you find.
Old May 10, 2013 | 03:15 PM
RedXJ40's Avatar
Thanks Jeeves12 for all the info.
My coolant is not green?
It is red?
Old May 16, 2013 | 10:17 AM
RedXJ40's Avatar
Problem solved, AC compressor replaced, and a seal in the transfer case also replaced.
Shes now 100% new again :-)
H20boy
Dec 24, 2024 03:23 PM
Rivguy
Dec 4, 2020 07:55 AM
arskemp
Sep 21, 2015 02:19 PM
Ipc838
Sep 13, 2015 03:27 PM
user 652867429824
Sep 5, 2015 12:53 PM
