Vacuum Lines
Old May 24, 2018 | 12:20 PM
Jim Burke's Avatar
Default Vacuum Lines
Does anyone have a detailed drawing or photo of the vacuum lines for the X Type?
Old May 24, 2018 | 12:37 PM
avern1's Avatar
There should be a sticker under the bonnet on one of the flat surfaces that details the engine vacuum lines. If it is worn away you can got the the "How to" section and at the bottom of the page download the Shop manual. It is the last listing at the bottom of the page.
Follow this link: https://www.jaguarforums.com/forum/x...essories-5915/
Do you have a vacuum leak problem? The common culprits are the PCV hose to the manifold, the IMT vale O-rings and the brake booster line.
Old May 24, 2018 | 01:21 PM
Jim Burke's Avatar
Replaced the PCV hose with the correct part and replaced the brake booster line. I'm trying to find the O-rings for the IMT. There is one vacuum line next to the break booster and I can't seem to find a name for it.
I will try looking at the manula.
Old May 24, 2018 | 01:46 PM
Jim Burke's Avatar
On occasion I receive a message that the cruise control is not available. It comes and goes. I thought maybe it was a vacuum leak.
Also on cold mornings below 45 degrees F the engine runs very rough and wants to die. I have to depress the gas pedal and try to keep the RPM's above 1,000 until the engine warms up. Currently since it's a lot warmer outside I have no issue at all with the rough idle at start. However I still get the random message about the cruise control.
Old May 25, 2018 | 12:41 AM
Dell Gailey's Avatar
This one?
Old May 25, 2018 | 12:55 AM
Or this one =
Old May 25, 2018 | 06:02 AM
Jim Burke's Avatar
Originally Posted by Dell Gailey
This one?
I replace that one. The line I am having issues finding is to the right of this line.
Old May 26, 2018 | 02:11 PM
dwclapp's Avatar
Jim Burke: You're probably looking at the vacuum line running from the top of the intake manifold, next to the throttle body, back to the firewall, next to the brake master cylinder. That's the purge line for the evap system, pictured in this post, under and perpendicular to the brake vacuum line:
https://www.jaguarforums.com/forum/x...9/#post1333979
Your X-Type's symptoms clearly point to a vacuum leak, but not likely from the evap purge hose. You've already fixed 2 of the top 3 vacuum leaks on our X-Types: PVC hose and check valve in the brake vacuum line. The 3rd leak - the IMT O-rings is likely the problem. Many threads discuss this leak and repair because it's so common:
https://www.jaguarforums.com/forum/x...roblem-113287/
https://www.jaguarforums.com/forum/x...cement-153568/
Old May 26, 2018 | 04:55 PM
Jim Burke's Avatar
Thank's I will replace the two o-rings and go from there. Now I will have to hunt them down.
Old May 26, 2018 | 06:29 PM
dwclapp's Avatar
Jim Burke: The part number is C2S40669 for IMT O-rings.
Here's a supplier: Control Valve Seal by Motorcars Ltd part C2S40669 - MotorcarsLtd.com
A independent mechanic near me who specializes in European cars had them in stock for ~$3 each as I recall.
Old May 26, 2018 | 08:48 PM
Jim Burke's Avatar
Thank's
joycesjag
16
Feb 21, 2026 05:52 AM
mirisisa
Dec 18, 2019 09:13 AM
91xj6owner
XJ40 ( XJ81 )
Dec 22, 2010 12:27 PM
1BUM
Jun 9, 2010 11:40 PM
fall4it
XJ40 ( XJ81 )
Sep 13, 2009 03:13 AM
