Volvo Rear Upper Control Arm
Old Feb 23, 2024 | 08:55 PM
BuckleSpring's Avatar
Default Volvo Rear Upper Control Arm
I was out getting an alignment for my X-Type today, got the printout back, and noticed the camber on my rear right wheel was on the higher end of the Jaguar acceptable specifications. From the naked eye it looks fine, but I assume my rear upper arm bushings are probably just getting worn. I was planning on replacing it with a standard X-Type arm, but then I got to thinking about it, and it would be a good opportunity to upgrade if I can.
I've seen people do the rear upper arm (Thermo) mod with the adjustable arm from a Volvo S40. However, is this doable with one of the standard non-adjustable Volvo arms? I assume the bushing distance and everything is the same... If reading through the old Thermo Mod thread holds true, the Volvo arm is beefier/stiffer and even if non-adjustable should be an upgrade, no? Also they're ~30% cheaper than the equivalent X-Type arms, so if they're better, and cheaper... seems like a logical swap to me.
Old Feb 24, 2024 | 06:06 AM
Thermo's Avatar
Veteran: Navy
Bucklespring, you are correct in some aspects, but I think you are also missing a key point. Yes, the arm should help out with things. But, part of the reason that the rear tires are leaning in is because the springs are sagging. So, if you had new springs, then yes, your logic is sound. But, with worn springs, that is why you need the adjustment. not all springs sag the same way.
Old Feb 24, 2024 | 11:59 AM
Ah interesting. I'll try and get the car in the air when I have time. What's the official spec I should be looking for in terms of ride height?
Let's hypothetically assume they're not sagging (even though they probably are), what's the viability of the Volvo arm vs the Jaguar arm? I have no doubt that mine are probably worn, again, with the mileage.
Old Feb 24, 2024 | 06:23 PM
Yorta2's Avatar
I have Volvo non-adjustable upper arms on my X Type. They have been there for around 3-4 years and are doing fine.
Old Feb 24, 2024 | 06:41 PM
Dell Gailey's Avatar
I have them and they are fantastic
Old Feb 24, 2024 | 10:24 PM
The adjustables or non-adjustables? If non-adjustable, any issues regarding rear camber?
Old Feb 25, 2024 | 02:00 AM
Thermo's Avatar
Veteran: Navy
Buckle, grab the JTIS from the stickies at the top of the page. Inside that, it gives the ride heights. This is also a good reference for a lot of repair stuff.
Old Feb 25, 2024 | 10:10 PM
Adjustable (Thermo) type
andybsmith
Dec 22, 2017 04:59 PM
Kdog
Jul 1, 2017 10:57 AM
Duncan2004
Dec 15, 2015 11:28 AM
afonda
Apr 13, 2013 07:52 AM
Pacecar
Mar 24, 2011 08:08 PM
