weird ticking/ clicking noise
Old Apr 11, 2023 | 11:27 PM
HELP's Avatar
Cool weird ticking/ clicking noise
Hi ,
I have this 2004 x-type 3.0L 6 AWD.
My friend was just fooling around and tried to do a
burn out and when he did it there is some type of sound
that is coming not sure what it is would you guys have a idea?
this is the sound:
Old Apr 12, 2023 | 12:12 AM
sov211's Avatar
Much too brief to be able to even hear the noise properly.
Old Apr 12, 2023 | 12:40 AM
HELP's Avatar
ohok that is a snippt of the sound I could send the whole vid but not sure it will help also idk if it will be safe to do it again?
Old Apr 12, 2023 | 12:43 AM
HELP's Avatar
here is the full vid:
Old Apr 12, 2023 | 05:50 AM
Blues boy's Avatar
You do realise you are trying to do a burnout in an AWD car don't you which is notoriously difficult to do. You are trying to achieve one of the things that the system is designed to overcome ,namely wheel spin..The clicking you are hearing may well be coming from part of the transfer system voicing it's protest !
Old Apr 12, 2023 | 10:01 AM
HELP's Avatar
oh so it's just system stoping it from spinning the tires, could it also beba axle issue?
Old Apr 12, 2023 | 10:54 AM
sov211's Avatar
What I see and hear in the video is, well, ...abuse of the systems in the car. Trouble ahead.
Old Apr 12, 2023 | 12:48 PM
Dell Gailey's Avatar
He broke his kitty!
Old Apr 12, 2023 | 01:42 PM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
That's the sound of very large denomination coins being thrown into a trash bucket, one after another.
Have that friend of yours that just destroyed your car crawl under it as it is running, in order to tell you exactly where the noise is coming from, and after he finds it put your car into gear and drive back and fourth over his head.
You used to own a fine luxury car. I have never, ever read anything that described it as a "Sports Car"
Old Apr 12, 2023 | 02:04 PM
HELP's Avatar
AHAHAH sure will do
Old Apr 12, 2023 | 02:07 PM
HELP's Avatar
the car still works fine and everything the break pads are brand new too... how the car broken?
Old Apr 12, 2023 | 02:30 PM
Norcat's Avatar
From my earlier tears of repairing auto boxes it sounds like a cracked flex plate. In the vid it comes when you apply load to the engine by trying to drive against the brakes, the flexplate is a metal disc bolted between the crankshaft and torque converter, big job if it is. You need to listen at the end of the engine under the battery box.
Old Apr 12, 2023 | 02:49 PM
HELP's Avatar
ok will do thanks
Old Apr 12, 2023 | 02:58 PM
HELP's Avatar
what other things could there be to it if its not the flex plate?
Old Apr 13, 2023 | 03:14 AM
Blues boy's Avatar
Perhaps it might be a good idea to tell your friend to go and trash somebody else's car. As I said he;s trying to do something that the AWD system is designed to stop happening.It will end in tears and a hefty bill.
Burn outs and Jaguar saloons , really .?
Old Apr 13, 2023 | 03:48 PM
h2o2steam's Avatar
The only smoke that should come from a Jaguar saloon should be that derived from fine tobacco!
Old Apr 14, 2023 | 02:31 AM
Blues boy's Avatar
Correct Sir.
Old Apr 15, 2023 | 10:21 AM
Or that coming out of one's ears after some dolt attempts the above...
iownme
May 6, 2023 02:34 AM
Jagstefano
Jun 24, 2017 11:58 AM
jagdaddy
Jun 6, 2008 10:53 AM
Apr 25, 2007 03:46 AM
