where is my brake booster pipe?
Old Jul 6, 2010 | 08:33 PM
maikal_0011's Avatar
Default where is my brake booster pipe?
my dealer told me to change the brake booster pipe,
i want to look at it and show it to my mechanic friend and see if we can replace it on our own,
so anyone like to tell us where that is?
p.s. picture would be nice
thanks in advance
mike
Old Jul 7, 2010 | 09:21 PM
dennis black's Avatar
20 Year Member
go to my thread (MY X-TYPE PROJECTS AND INSTALLS ) YOU MAY HAVE TO GO THROUGH A FEW PAGES BUT YOU WILL FIND A WRITE UP WITH PICS AND LOCATION
Old Jul 8, 2010 | 12:09 AM
u r good with cars man,
i looked at your post and yes there is write about brake booster pipe but it only says that it's be broken, that's it and there is all different code for different error light, do u have any other post or can just tell me where it is? with picture it would be really nice and helpful at the same time
and i also have another question where did u get your grill from? and about wheel crome, i went on the website but didn't clearly get idea how much is it wouth, how much it cost you?
and after doing all this projects and install , how much is car worth now?
thank in advance
Old Jul 8, 2010 | 03:06 AM
Green Machine's Avatar
Question
thanks in advance
mike
I have a question for you. Why is your dealer telling you to replace the brake booster hose?
Do you have some engine trouble codes indicating a vacuum leak. If you don't have any trouble codes I don't understand why they are suggesting the hose be replaced. I would ask then to show me the hose and why it needs replacing.
Old Jul 8, 2010 | 11:39 AM
he just said that your brake booster pipe needs to be replaced,
engine or dashboard doesn't give any kind of error and i don't have problem with brakes, they just work fine
and i also asked him but i have to deal with advisor and advisor deals with technician and i asked him and he didn't know where it was, end of the story that's why i am never going back to jaguar dealership again
so u know where that pipe is?
Old Jul 8, 2010 | 12:27 PM
Brutal's Avatar
the pipe goes between the brake booster and the intake manifold. the black and grey check valve in the middle deteriorates being above the rear cats heat. it will eventually be a vacuum leak. to remove press in the black ring around the base then withdraw the tube from the intake. the booster side just pulls out, but grab close so you dont snap the plastic line. Now get some heat shring the same size as that check valve(1" approx) and heat shrink it over that and the line to seal. This how I normally repair. Or buy a new booster pipe theyre about $100+ take your pic couple dollars or a hundred
Old Jul 8, 2010 | 04:35 PM
that help lot but i still can't picture it
i will take your description to local autoshop and hope he will identify it
thanks
mike
Old Jul 8, 2010 | 07:16 PM
dstolp's Avatar
Brake boost pipe circled in attached pic. I replaced mine and found the O-ring in the intake was rock hard and had to be replaced. Had a really hard time getting it out of the intake because of how hard the O-ring was. I hadn't heard of the heat shrink fix I might have tried that method if I had thought of it.
Old Jul 8, 2010 | 09:22 PM
Thumbs down
For starters, I'd find a different dealership. If the service writer doesn't have any knowledge of what he's talking about then that's a clue to get out of there. If your not having any trouble with your brakes and not getting any codes displayed then I would say that the hose is OK. Are you having any problems with your car's performance that points to a vacuum leak?
Old Jul 8, 2010 | 09:55 PM
to dstolp, thanks for pic, i will check it out
and other members who helped me on this forum, i deeply appreciate it
thank u very much
Mike
Old Jul 8, 2010 | 10:17 PM
Brutal's Avatar
HELLO!!! Do you ever do preventative maintenance? Or do you wait till hoses burst, check engine lights come on, tires blow out? I meen really, they let him know it should be replaced and I would too if I saw it. How many people really like to wait till something fails and costs you more money, and untimely breakdown...Tow bills, sitting on the road, and if that pipe breaks, or becomes a big vacuum leak, you loose power brakes and end up with a very hard pedal....Thats just not good advise to let it go because he's not having a problem right now or check engine light...sorry its a cheap fix
Old Oct 4, 2010 | 01:06 PM
JagUR's Avatar
Default Brake Booster issue on 2003
Hi all;
Newbie on Jag forums, so let me know if this is the wrong spot to "add-on" to a booster thread. Would hate to start another thread when this might be related.
Ok here it goes....
Had a Rotors and Pads job on all 4's back in June this year. Car ran/stopped fine up until late.
1.) Had coolant refill hose leak that "ate" by brake fluid reservoir cap and contaminated the lines as it was hard to stop. Hard Brake Petal.
2.) Have associated?? Check Engine light and my famous and lovely CRUISE NOT AVAILABLE light. Gotta love that limp mode, especially on the highway.
3.) Had lines bled by very reliable Jag mechanic. Same issues still persist with hard petal and check engine lights.
Mechanic says fault codes point to booster (which is what we thought).
Couple of questions:
-Is is this in fact the booster gone bad or just the brake booster pipe.
-Are these faults (check engine light and Cruise Not Available) normal for a booster issue?
Sorry if this went on a bit, or posted in a incorrect spot. I have an Alfa Romeo that I work on and post to their BB and try to keep "like" threads together.
Thanks in advance and for the patience.
Old Oct 4, 2010 | 02:04 PM
@JagUR, it seems to be a logical spot to me.
Hopefully the guys will be able to answer your questions.
clubairth1
30
Sep 3, 2025 04:38 PM
xjrjag
Oct 24, 2024 03:09 PM
Tim Goz
Sep 17, 2015 09:11 AM
ayavner
US Southwest
Sep 16, 2015 02:43 PM
Andrew Fanshawe
Sep 14, 2015 07:40 PM
