White X-type w/ H&R springs-Pics* Question*
Old Oct 3, 2012 | 12:54 AM
funkdoktor's Avatar
Default White X-type w/ H&R springs-Pics* Question*
Hello everyone, I've had my X-type for almost 5 years now & I've decided to lower my car. I chose to go w/ H&r's due to the fact that it was the most affordable route. I'm pleased with the results. Not too high or too low. The only gripe I have is that it seems that the rear is lower than the front. Anybody have any clues to why this is? Or is this normal for H&r's? I was thinking it could be the factory shocks as I did not change them out when I switched out springs.
Thank you to Exexpat for answering questions I had before installing the springs.
Hope you guys like it!
Old Oct 3, 2012 | 05:28 AM
From the second pic, when concentrating on the wheels in relation to the wheel arches, the rear does appear lower.
However, the horizontal rubbing strips along the front and rear doors appear parallel to the ground.
Whether this is due to perception or confirmed by actual measurements, it still looks neat.
Old Oct 3, 2012 | 06:17 AM
Aonsaithya's Avatar
Looks nice.
What are your thoughts on ride quality prior and post?
Old Oct 3, 2012 | 01:46 PM
bracester's Avatar
So you kept the stock shocks...hows the ride with the stockies still on there?
Old Oct 3, 2012 | 02:04 PM
disguay's Avatar
funkdoctor, a member on here had the same problem that you had and they just cut off a half a coil in the front to even it out.
Old Oct 3, 2012 | 09:04 PM
ahhhhwhoa's Avatar
Mine sits exactly the same as yours right now and it bugs they heck out of me.. still waiting for pictures on this thread of the car with half a coil cut out...
https://www.jaguarforums.com/forum/x...springs-81629/
Old Oct 3, 2012 | 11:28 PM
funkdoktor's Avatar
The ride is surprisingly still comfortable. You can feel that its a little stiffer but its not harsh at all.
Is there any pictures the x-type? & is there any pictures how much exactly he cut? I'm considering doing this but I wanna see some reference pics to see how much to actually cut.
Thank you for the reply. I feel your disappointment. I'm considering cutting the front springs this weekend. How is "half a coil" measured?
Originally Posted by Aonsaithya
Looks nice.
Ride quality is a little stiffer but not harsh at all. Thanks.
Old Oct 4, 2012 | 02:36 PM
Patterson's Avatar
Here is my X on H&Rs. I think it looks pretty level, if not a touch higher in the rear.
Old Oct 4, 2012 | 04:38 PM
funkdoktor's Avatar
Looks really good Patterson. I see you have the sport version X-type. I wonder if that's why yours sits nice and level?
Old Oct 4, 2012 | 05:33 PM
Patterson's Avatar
Hey FunkDoktor, thanks. Are you, a DJ? Anyway, it might be that mine is a Sport. When I installed the H&Rs I also left the original shocks and struts in place. Here's something that shouldn't matter, but I don't carry the spare tire or the jack etc in my trunk. I figure all that gear is about 70lbs that I don't have in my trunk.
Old Oct 5, 2012 | 03:09 AM
Cambo's Avatar
I've got H&R lowering springs on my X-Type & it doesn't sit lower at the rear.
The ones in mine actually lowered the rear of the car further than the front from the factory heights, but it came out right in the end.
Details of the springs here https://www.jaguarforums.com/forum/x...40/#post547931
Old Oct 5, 2012 | 10:27 AM
exexpat's Avatar
If you have red springs, they could be a race spring and have different specs. Mine were black and the car sat too low in the back also (it is a Sport model). I think the stock sport springs in rear with H&R front would solve the issue or a coil/half-coil cut off the front. The last choice would be to see if the H&R X-Type wagon rear springs are available and try those in a sedan. (I'd cut a coil or much as you can without the spring seating funny in the perch.)
Old Oct 5, 2012 | 02:43 PM
funkdoktor's Avatar
That's a good idea. Thanks.
How did it come out right in the end? Thanks.
I have the red springs currently installed on my non sport x-type & my rear sits a little lower. Since the springs are progressive, what end should be cut? The end where the springs are close together or spaced out? Thanks.
Old Oct 5, 2012 | 07:38 PM
exexpat's Avatar
Ideally the dead coils should be cut. It depends on whether they taper in on top or bottom. Main thing is that they still seat correctly once everything is put back together.
Old Oct 5, 2012 | 11:47 PM
funkdoktor's Avatar
What do you mean by tapered?
Old Oct 6, 2012 | 06:57 PM
Patterson's Avatar
This is one of the front H&Rs being assembled. The loops taper at the top.
Old Oct 6, 2012 | 06:58 PM
Patterson's Avatar
Stock and H&R side by side
Old Oct 6, 2012 | 08:48 PM
Ricky305's Avatar
Here's my x-type on h&r. the front has half the coil cut but I'm destroying the inside of the tires. might do another alignment. sorry but shes super dirrrrty
Attached Thumbnails White X-type w/ H&R springs-Pics* Question*-photo1.jpg   White X-type w/ H&R springs-Pics* Question*-photo%5B2.jpg
Old Oct 7, 2012 | 01:08 PM
ahhhhwhoa's Avatar
which side (top or bottom) are you cutting the coil from?
Old Oct 10, 2012 | 04:53 AM
funkdoktor's Avatar
Thank you Ricky305 for posting pics of your ride. where did you cut the spring from, top or bottom? & could you explain what exactly is half a coil?
