wood key?
Old May 19, 2008 | 08:05 PM
jvegas's Avatar
Default wood key?
I had another Jvegas idea! What about a woodgrain key fob? Made out of the same wood as the dash? It can't be that hard to carve such a thing and just take the guts out of the old key fob and put into the new wood one... what do you think?
Old May 19, 2008 | 08:11 PM
ibjags's Avatar
Default RE: wood key?
i think it would be cool if they existed but personally i wouldnt even try lol
Old May 19, 2008 | 08:28 PM
Thermo's Avatar
Veteran: Navy
Making the keyfob out of wood may not be a good idea. I say this only because you will have fairly small pieces of wood that will be forced to run against the grain. This is going to lead to something that will break pretty easy when any force is placed on it. I know it wouldn't survive more than about a week inside my pants pocket. Now, if you could make a piece that would slip over the current key fob (say 0.07" thick) and use the plastic underneath as a support, then you might be good to go.
Chris "Thermo" Coleman
Old May 19, 2008 | 08:32 PM
jvegas's Avatar
well here is what i thought. If the key fob was carved out of two pieces and then coated with something on the inside to make it strong. then put the guts into it and glue the two parts togather.
Old May 19, 2008 | 08:35 PM
ibjags's Avatar
if glued together how would you change the batteries
Old May 19, 2008 | 08:48 PM
jvegas's Avatar
lol... ok so i guess i forgot about that. i guess a door like the OEM one has?
Old May 19, 2008 | 08:58 PM
ibjags's Avatar
give it up
lol
Old May 19, 2008 | 09:48 PM
jagxtype's Avatar
I vote making it out of soap...much cooler and it will smell good
lmao
Old May 19, 2008 | 11:51 PM
pu5hkar's Avatar
(jagxtype) lololo true humor
Old May 20, 2008 | 12:05 AM
loaks111's Avatar
go to a site about marquetry. i think that's how it's spelled. you can find wood veneer to match close or right on to your dash.if you fashion a similar fob and glue the venner to it you could have it. just my under valued american 2 cents worth. damn federal reserve.
Old May 20, 2008 | 06:04 AM
Cadillac's Avatar
That sounds a good idea but practicability might be an issue lol
Old May 20, 2008 | 10:33 AM
aquill1's Avatar
Take the fob to a wood worker and see what he could do! Depending on the wood you use it could be more solid than the plastic itself. Especially once stained and varnished...here's the wood baby crib I made by hand...
Old May 20, 2008 | 03:08 PM
tarheel72's Avatar
JV, did you see the wooden key fobswith emblems located on this pageunder Key Chains:
http://britishautowood.com/gearknob.html
Contact Saul and ask him if he can custom make one for you like you want. If it can be done, he will do it. he can put a small screw in it tohold the sides together so you can stillseperate the two halves for changing the battery. Question is how much do you want to spend on it.
Old May 20, 2008 | 03:33 PM
aquill1's Avatar
Hmmm...those look sweet...
Old May 20, 2008 | 04:14 PM
jvegas's Avatar
yeah but that is just a key ring not a keyfob. i will email him tonight and ask if he can make it and if so, how much.
Old May 22, 2008 | 12:16 PM
ancientsanskrit's Avatar
lmfao...you jag boys are nuts!
Uhhh, I'm not sure how you guys keep your keys, but mine goes in my pocket/ignition 99.9% of the time. Unless you plan to tape it to your forehead, I don't get it. [:'(]
Old May 22, 2008 | 12:59 PM
jvegas's Avatar
i just think it would look nice while in the ignition with the matching dash..
Old Jun 24, 2008 | 11:05 AM
bluejaggg's Avatar
^Agreed
Lots of people see my with my keys.
A key fob that matches my dash?
Id buy it! And the keychain to go with it!
AllI can see is a keyring though
Old Jun 24, 2008 | 01:27 PM
H20boy's Avatar
Vegas, ever find anything out about your wooden remote?
bdboyle
Sep 16, 2019 05:58 PM
Johnken
Oct 2, 2015 10:12 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
Jzar
Sep 27, 2015 02:55 PM
