X Type Drive Belt Noise
Old Mar 6, 2019 | 10:57 PM
Striker27's Avatar
Default X Type Drive Belt Noise
Hello,
My quest to bring my Jag X type 2.5 with 140000 KM into better then it was condition is continuing!!
At present I am experiencing a strange knocking noise coming from the area of the Water Pump, Pulley or Tensioner . This is the belt behind the battery box on the engine. The area that has just the larger Pulley is seeping oil, the pulley itself is also kinda loose and wobbles....
Has anyone had a similar issue with this area around this pulley having a leak?
Has any one replaced this part or the pulley if it has a wobble??
Old Mar 7, 2019 | 12:17 AM
Dell Gailey's Avatar
The one on that side is the water pump one.
Old Mar 7, 2019 | 03:51 PM
Striker27's Avatar
https://youtu.be/lswd2ESMbjE
Yes can I ask what the larger pulley in this video is? That is the one that has the wobble??
thanks
Old Mar 7, 2019 | 08:29 PM
watto700's Avatar
G'day Striker,
Of the three pulleys on that side of the engine the largest one is driven by a coupling from the front camshaft and by the belt drives the water pump. The small pulley towards the rear of the engine is the water pump pulley and the small pulley towards the front of the engine is the spring loaded belt tensioner.
Have you tried tightening the three bolts which secure the large pulley? Maybe they have worked loose. If the water pump has been replaced these bolts will have been removed and replaced.
The large pulley has it's own shaft and bearing, have a look here at item #12, the bearing may be worn.
https://www.jaguarclassicparts.com/a.../water-pump-v6
Cheers,
Jeff.
Old Mar 8, 2019 | 06:46 PM
car5car's Avatar
It is going to cost you $5, go there, they have 5 Xs.:
acepickapart.com
Old Mar 9, 2019 | 12:41 AM
Striker27's Avatar
I would love to get it for $5.00. Just no where near me!! Do you have to buy the whole assembly or is just the bearing available??
it is making an awful clunking noise!!!
thanks.
Old Mar 9, 2019 | 01:55 AM
Entire assembly =
https://www.ebay.com/itm/For-Jaguar-...AAAOSwEzxYP-7a
There is just the bearing on UK site for like £18 + £9 shipping (in UK, would be a bit more to you).
Old Mar 10, 2019 | 07:27 PM
Striker27's Avatar
Any chance you may know where to get just the bearing?? You mentioned a few british sites.
Old Mar 11, 2019 | 01:32 AM
Yeah, enter search in google and it's on the UK eBay site
Old Mar 11, 2019 | 02:53 PM
Striker27's Avatar
I was able to find a used one did you come across a new one??
thanks
Old Mar 11, 2019 | 06:07 PM
No new ones are available, you have to buy the entire assembly.
Old May 2, 2019 | 11:20 PM
Striker27's Avatar
I replaced the entire assembly the noise is gone also replaced the coolant hoses and the coolant expansion tank. Car is running much better... Weird now getting a GEARBOX Fault in Yellow and I have a flex coupler with a tiny leaking the exhaust!!
LMAO
THANKS GUYS!!!
Old May 3, 2019 | 10:11 AM
car5car's Avatar
I went to Advance auto and checked all pulleys. One of them looked exactly like w.p. tensioner pulley, but price was about $40. I'll try to find part number.
Old May 3, 2019 | 02:08 PM
And.....the troll returns.....
Old May 3, 2019 | 02:32 PM
car5car's Avatar
Hello, moron! Nice to see your dumb posts here. My X was gone couple weeks ago, I didn't start repairing my XK yet. Did you pay for fuel tank removal $800 yet? Be nice, maybe I'll teach you how to remove fuel tanks. Did you graduate high school? Trying to understand if you have high enough IQ for that. No, probably not.
Old May 3, 2019 | 03:54 PM
Lol, actually 6 degrees. As I told you before, trolls are usually undereducated people trying to pretend in cyber space that they are something they will never be in RL.
Old May 3, 2019 | 09:49 PM
car5car's Avatar
I must be highly educated guy because I know how to remove fuel tank! I can teach you how to change oil and brake pads.
what is RL?
Today I finished differential rebuild for my Dodge Durango, is it considered more complicated job than fuel tank removal?
Plugger22
Aug 18, 2018 10:01 AM
Teck4Jag
Sep 22, 2017 02:26 PM
saxchappy
Apr 15, 2017 07:33 PM
XKR2000
Sep 5, 2014 07:57 PM
manoeuvre
Sep 7, 2011 12:52 PM
