X-type radiator with a hairline crack
Old Aug 16, 2012 | 04:59 PM
konshu's Avatar
Default X-type radiator with a hairline crack
Hey guys can anyone hit me with an R&R for the o3 x-type radiator? I gotta get this thing replaced ASAP.
Old Aug 16, 2012 | 06:09 PM
Thermo's Avatar
Veteran: Navy
Konshu, look on e-bay. You can get a radiator for your car for anywhere from $145 to $350+ depending on whether you want a brand new one or a slightly used one. Replacing a radiator in our cars is not that difficult. So, if you have some basic mechanical skills, you can replace it yourself and save yourself a lot of money. If you pay a shop to replace it for you, plan on spending about $600 to have it done.
Old Aug 16, 2012 | 07:10 PM
c.3823's Avatar
Thermo is spot on with his advice to purchase an ebay radiator. I've used them on several other marques-no worries. SOMETIMES a tank can repaired with eboxy and some fine stranded wire-again, that's SOMETIMES...then you get to think about the possibility of your repair failing at the worst location on earth (you pick the location)...just buy the cheap ebay radiator and put it in yourself...OR...buy a case of brew,get a petrol head buddy to install the radiator, then and ONLY then bring out the beer for some bench racing. Cheers, Andy
Old Aug 16, 2012 | 07:33 PM
konshu's Avatar
thanks fellas. picked up one today for $200. now in the garage and dont know what to take off 1st. got all the prelims out of the way but detatching the radiator from the car looks like it has a certain protocol. Fans 1st?
Old Aug 17, 2012 | 03:52 AM
The guys will probably have a quick method for this but if not, here's the JTIS section on radiator removal:
JTIS - 2003 X Type Radiator.pdf
The procedure includes Cooling Module removal. This file is too big to attach but you can download it from my MediaFire account by following this link:
Free Cloud Storage - MediaFire
Looks like fun - not!
Old Aug 17, 2012 | 09:02 AM
konshu's Avatar
thanks G.
Old Aug 17, 2012 | 05:15 PM
konshu's Avatar
quick update fellas: R&R done, test drive went on a 12-15 mile run but by the time I got back home it was overheating. So....gotta check that out but Thanks for all your help.
Old Aug 21, 2012 | 12:56 AM
Emanx2.5's Avatar
Hows it going fellas?...I also need to replace my radiator and I was hoping I could do it my self since the dealer was charging me $1,200.00!!! What are these straps I need to hold the ac condenser with? Is there an easier way to remove the radiator or is this the only method? Thanks for the help
Old Aug 21, 2012 | 01:15 AM
Emanx2.5's Avatar
One more thing how do I perform a coolant flush? Do I just drain, fill with water, run the car and drain again?
Poet
Oct 6, 2015 09:40 PM
hoodun
Oct 2, 2015 10:13 PM
Blaine Trarop
Sep 23, 2015 03:08 PM
jaggermang
Sep 8, 2015 07:07 PM
ftypel
Sep 5, 2015 10:15 PM
