X TYPE Transmission
Old Apr 19, 2008 | 12:47 PM
ness's Avatar
Default X TYPE Transmission
I have an 02 x type sport automatic. after second gear it goes into neutral wont go into third brought it to a mechanic and they said the transmission fluid was low so they towed to a jaguar dealrship to have it filled when the car came back it was still doing the same problem and they said that i needed a new transmission!!! the check engine light is on.
Old Apr 19, 2008 | 12:52 PM
jag_genius's Avatar
Default RE: X TYPE Transmission
sounds like your trani goes into limp home mode.. as soon as in 2nd it sees a problem.. post the codes... and codes for incorrect gear ratio .. then you do need a trani..
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Raul Lara
Sep 14, 2015 07:31 PM
laserguy
Sep 3, 2015 02:02 PM
dcvickers
Sep 2, 2015 06:14 PM
